1st Gen Taco, evap canister questions...
Old 06-17-2014 | 09:27 AM
1985 4Runner's Avatar
I have a 2002 Tacoma 2.7 now.
Topped off the gas in my new to me 02 Tacoma 2.7 & did not know I was NOT supposed to top off the tank. Result was fuel overflowed into the evap canister I think.
Check engine light has been on since. Ran the codes & got P0440, P0441, P0446
If I can't get the light to reset & stay off I'm looking at having to drop the tank & replace the evap vapor canister. Alternate/OEM Part Number(s): 7774004010, VC4056
I have purchased a replacement evap canister.
Has anyone replaced this part? I read that I may have to remove the bed or drop the gas tank, then I read I may not need to do either.
Looking for clarification or advice. Thanks.
Old 06-17-2014 | 10:36 AM
wyoming9's Avatar
Red face
Not sure about your 2002 and it being a 2.7
But my 3.4 2000 the evap canister is in the engine compartment on the left inner fender.
Toyota could very well moved things for some reason
I have no idea why Topping off or having a pump that didn`t shut off which happens to me quite often.
If this was a problem what happens in the sun when the gas expands The gas door would be plastered with warnings .
Would trigger your codes .
It can be caused by a bad gas cap gasket.
Then it can be caused by quite a number of things the evap canister is only one.
I for one would want to know just what the real problem is before changing good parts.
Unless your truck has like 250,000 miles and is in need of a major restore
suppra87
07-15-2021 06:15 PM
clok
11-19-2015 02:09 PM
joeynational
09-05-2015 02:54 PM
Badfish740
09-04-2015 05:21 AM
