1st Gen Air Induction Service
Old 06-10-2005 | 07:28 AM
toyotablue's Avatar
I took the 1988 toyota 4-runner into the Dealership yesterday. It was idling at about 300 rpm, and I thought it was going to die at every stop light I came to.
Anyway, the problem was described as the "IDLE AIR BYPASS PASSAGE GUMMED UP WITH CARBON DEPOSITS". The fix: "REMOVED IDLE AIR BYPASS VALVE TO ACESS PORT FOR CLEANING". That being done seems to have fixed the problem.
However, the dealership always has something they recommend you do in addition to what they do to fix the job you request they fix. They recommended: "TECH RECOMMENDED AN AIR INDUCTION SERVICE TO CLEAR THE OTHER PORTS AND PASSAGES OF CARBON BUILD UP. EST $130
He described it as using some kind of fluid they run through the system. How can I do this on my own? What kind of fluid do you think they were talking and where do I pour it into my 1st Gen V6 engine? thanks,
Old 06-10-2005 | 08:37 AM
SupraSport's Avatar
UMMMMMMmmmmmm....... thats a pretty fancy name.
"AIR INDUCTION SERVICE" aka $130 BS
To help your idel:
Replace all you vacume lines (ONE AT A TIME PEOPLE!!!! LOL)
Fuel injector Cleaner in gas tank
Remove throtle body and clean inside with brake cleaner so that the flap seals nicely on the housing (be sure to re-install with a new gasket)
PCV replacement
Timing
Spark Plugs, Air Filter, Fuel Filter, Basic Tune Up ect.....
ENJOY
Aaron =)
Old 06-11-2005 | 08:08 AM
How about the famous "seafoam" through the PCV valve. that is prolly what $130 air induction service is.
Old 06-11-2005 | 08:45 AM
Beartracker's Avatar
Never got the hang of Sea Foam through the PCV valve hose. As soon as I pull the hose off me PCV valve the engine stalls.
Old 06-11-2005 | 02:01 PM
Adam F's Avatar
It shouldnt stall. it might stutter, but not stall. Try giving it some gas to keep it alive.
Eggslinger
06-08-2019 04:32 PM
calderp
Engine Swaps
08-16-2016 06:15 PM
calderp
07-27-2015 10:58 AM
noahstancik
07-17-2015 06:38 PM
coryc85
07-06-2015 05:07 AM
