1997 4Runner Tranmission Clunk
Old 03-17-2013 | 09:11 AM
chrisorbics's Avatar
1997 Toyota 4Runner Limited 4x4 automatic. I have been noticing for awhile that when I come to a stop and then let off the brake pedal and accelerate the transmission and the shifter jump. It feels like a loose mount. I looked at the bottom mount between the transfer case and the crossmember which looks ok.
Has anyone had a similar issue? Any thoughts on what and how I should check it?
Old 03-17-2013 | 10:23 AM
rworegon's Avatar
When is the last time the driveline was lubed? Loose motor mount?
Old 03-17-2013 | 11:45 AM
white_n_slow's Avatar
check your driveshaft u-joints. They usually clunk before going out all together.
Old 03-17-2013 | 12:16 PM
98SR54RUNNER's Avatar
Like others have said, most likely your u-joint. It needs a greasin'.
Old 03-17-2013 | 02:03 PM
tgmaul88's Avatar
change your trans fluid and filter id know the same clunk was on my 4runner untill i put new fluid and a trans filter in it and then no clunk
Flying91
45
04-11-2024 05:39 PM
06-01-2021 02:51 PM
icentropy
09-16-2020 03:47 PM
BeMiceElf
10-10-2015 10:40 PM
Poppie51
07-23-2015 06:03 PM
