View Poll Results: Which body lift do you recommend??
Go with the 1" Roger Brown body lift!
94
47.24%
Go with the 2" Roger Brown body lift!
74
37.19%
Don't do it (no body lift at all!)
31
15.58%
Voters: 199. You may not vote on this poll
1" or 2" Roger Brown body lift??
#64
Originally Posted by hillbilly
Hey.... I like the 1½" idea. Thanks Victor. Didn't realize I could get one that splits the difference.
As far as the hitch goes, I'll never take it off. I specifically looked for a 4Runner with a hitch and man am I glad I did. The hitch has paid off numerous times in the short 1½ years I've owned it. I use it fairly frequently. I've hauled tons (no kidding) of firewood, lumber supplies, and a ton (literally) of porcelain tile flooring that I pulled out of my kitchen to the transfer station (a.k.a. dump). Plus, I have a bike carrier for the hitch and an aluminium fold up cargo carrier (rectangular basket) I use all fall/winter to cart deer carcasses home after successful hunts.
I've thought about the custom bumper, but the Rockware I want is pretty spicey ($650+). With that kind of tag, I won't be seeing one anytime soon....
Anyone have any idea how easy/difficult it would be to modify an '01 OEM hitch to move it up 1½"???
#66
- http://www.4crawler.com/4x4/ForSale/...eringExtension
Some can be extended in place, others need an extension.
#68
Not currently:
http://www.4crawler.com/4x4/ForSale/...Kit.shtml#FAQ5
#70
On a 1" you can get away with spacers and bolts and maybe having to remove the bottom of the fan shroud.
Perhaps the steering spacer if you wish and the bumper mounts brackets.
I've done several 3rd gens and it takes about 2 hours taking your time.
#72
A 2 inch lift sounds good to me.
I just pray when i get it all installed i dont have steering or shift linkage issues.
If i put a 2" bl, put 1" blocks in the rear and cranked the TBs down 1" up front then that should be an extra 3 inches for tires no? (please correct me if i am wrong)
Im running 31x10.50s now but would like to get closer to 33s or maybe even 35s.
The only reason i am planning on doing this is i can not afford a SAS at the moment. There is no point in lifting IFS imho (lifting the suspension). Too much money just to start replacing cv shafts.
#73
Steering is easy to deal with:
http://www.4crawler.com/4x4/ForSale/...irculatingBall
as are the shifters:
http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Flying91
45
04-11-2024 05:39 PM
09-04-2015 10:27 AM
Backcountry411
07-24-2015 09:06 AM
