View Poll Results: Which body lift do you recommend??
Go with the 1" Roger Brown body lift!
94
47.24%
Go with the 2" Roger Brown body lift!
74
37.19%
Don't do it (no body lift at all!)
31
15.58%
Voters: 199. You may not vote on this poll
1" or 2" Roger Brown body lift??
Old 02-17-2005 | 06:02 AM
lee's Avatar
lee
this thread is old...
Old 02-17-2005 | 07:25 AM
turboale's Avatar
2"
There isn't a gap you can't cover...
Old 02-17-2005 | 08:23 AM
payyourtoll's Avatar
where is the 1.5" vote option?? Go 2" if you cant decide
Old 02-17-2005 | 09:50 AM
BruceTS's Avatar
Originally Posted by RIPPER
Personnally I would get the 2" lift just for the functionality of it. What is the difference betwen the "Roger Brown" BL and 4Crawler . When you click on Roger Browns link it brings you to the 4 Crawler site. Is this the same BL or did Roger Brown change it? Just wondering.
Roger Brown is 4Crawler
The only time you should add a body lift is when you need to clear larger tires, in my case the 265/75-16 BFG AT's were 31.8" diameter and I wanted to run 315/75-16 MTR's at 34.8". Since I had minor rubbing with the BFG's that I didn't mind I went with a 1 1/2" RB BL, the difference in the tire diameters, divided by 2.
BTW this is an old post, but it's better than starting a new one on the same subject.
Old 02-17-2005 | 10:16 AM
  #25
TStango's Avatar
I had a 1" and went to 2" to eliminate some rubbing. Do it right the first time. Go for 2".
BTW Austin, I was checking out your write up again on the hitch flip mod. Do you have any pictures of it now that you have your 2" BL? I've been wanting to do this for a while but I still haven't got around to it.
Old 02-17-2005 | 10:36 AM
  #26
bamachem's Avatar
starting w/ jimabena...
this thread was dug up from it's grave. it died sometime in mid sept of 2003! lol...
you have been voting and responding to someone who has a 1.5" RB BL listed in their sig.
Old 02-17-2005 | 01:45 PM
  #27
Bigkahuna808's Avatar
Is there somthing like 2.2, I need a little more clearance up front for my truck, I still rub on full articulation. But then again Im gonnna re build my front suspension so that might fix it. But U did a 2" and it rocks
Old 02-18-2005 | 10:45 PM
  #28
4Crawler's Avatar
4Crawler Offroad is the company and Roger Brown (that's me) works for the company. I've been trying to clear up any posts and web pages with the confusing information. Afterall, you probably use Microsoft Windows on your PC, not "Bill Gates" Windows
I added a section on the 4Crawler Offroad body lift kit that hopefully clears this up:
http://www.4Crawler.com/4x4/ForSale/...it.shtml#FAQ12
Old 02-19-2005 | 05:59 AM
  #29
3car's Avatar
Originally Posted by jimabena74
i voted 2" because 3" wasnt an option... think of it this way... you will always be kicking yourself later when you realize that extra litte 1" could make soooo much difference
he has probably decided on a body lift in the 2 years since this thread was started. why bump this?
Old 02-19-2005 | 06:06 AM
  #30
bamachem's Avatar
hey, i might have something for you. you know i've been having spacers cut out of HDPE for a while now. well, then center cuts from the "donuts" are the perfect size to be a "trimpacker" for one of rodger's kits. they're 3/8" thick, so 0.375". i could drill out a set of 10 and ship them to you for pretty cheap. all you'd have to do would be to jack the body off the frame (like when installing the body lift the first time) and slide the spacers in on top of your current lift blocks, then reinsert the bolts and tighten down. you'd end up w/ a 2.375" body lift. you could do two spacers per body mount (one top and one bottom) and have 2.75", but for 0.75", you'd probally have to get longer bolts locally.
Old 02-19-2005 | 10:23 AM
  #31
ScottyBean's Avatar
1" is too small, and 3" is too big, Go with 2" . I have one in my 96 with no problems.
Old 08-02-2005 | 08:14 PM
  #32
ROOFGOOF's Avatar
I like my 2 inch BL, pictures on my link below if you want to check it out. I own a 99 4runner.
edit---Dumbass me I just saw the post date...
Old 08-02-2005 | 08:41 PM
  #33
Ironmike4x4's Avatar
Hijacking the thread here, but is Yoter back on this board again?
Edit: Doh!! Nevermind, I saw his post date.
Old 08-02-2005 | 08:59 PM
  #34
rocket's Avatar
lol. This thread has died 3 times. It was posted in 2003. There called '4Cawler' body lifts (not Rodger Brown). The guy that posted it now has a 1 1/2" BL in his sig.
How much more ridiculous can it be?
Old 08-03-2005 | 09:27 AM
  #35
hillbilly's Avatar
You're right... I've been running a 1½" RB BL since Sept/Oct of '03.
Old 08-03-2005 | 09:34 AM
  #36
bump.
  #37
hillbilly's Avatar
Old 08-03-2005 | 03:30 PM
  #38
Ha ha just gotta dig up the old threads sometimes, hey hillbilly what happened to your old avitar with the redneck looking out of a window?
Old 08-06-2005 | 06:59 AM
  #39
waskillywabbit's Avatar
He drove into the campfire.
Old 08-08-2005 | 04:33 AM
  #40
hillbilly's Avatar
Originally Posted by waskillywabbit
He drove into the campfire. :hillbill
LOL... no. Just thought it was time for a change. Is my new choice not up to par?
