'02 Foglight bulb replacement?
Old 06-22-2005 | 09:21 PM
DavidA's Avatar
I ordered some ION Yellow 55w H3 bulbs to go in mine...we shall see...
Old 06-23-2005 | 08:20 AM
Fink's Avatar
Those should work fine...good luck with the install. Take it easy with the muscles on those screws they strip like no other!!! I had to replace most of the screws in mine..well I had the dealer do it cause I work up there now but...either way...just be careful. Try a bunch of different screwdriver heads before torqueing on anything.
Just a heads up for a ya David!
Fink
Old 06-28-2005 | 11:09 AM
BikKat's Avatar
I have replaced my bulbs and I have removed no screws to do so, what screws are you removing? You just pop the wire holder out of the lock and move it up and slide the old bulb out and disconnect the wires and attache the new bulb . . . or did I miss something?
SLG
Old 06-28-2005 | 11:29 AM
Beartracker's Avatar
SLG, I ddn't know you had to take out any screws either. Maybe different years work differently.Mike
Old 06-28-2005 | 11:44 AM
  #25
DavidA's Avatar
I see three screws underneath the unit. I assume those are the ones they are talking about, then the bulb mount must drop down and out of it.
Old 06-28-2005 | 09:35 PM
  #26
Fink's Avatar
Yes, there are 3 small screws holding it in place. Remove those, let the cover hang down, remove the screw holding down the wire for the bulb and you're in business.
Fink
mskalmus
05-28-2017 08:51 AM
TURBOrunnerNM
07-22-2015 12:01 PM
rushw
07-18-2015 02:46 PM
1994toyota
07-17-2015 04:03 AM
madxman21
07-09-2015 11:26 AM
