01 4runner alarm has locked ignition
The natery was disconnectedband reconnected, I have no FOB and cannot figure out how to unlock the ignition. Best I can tell it has a dealer installed alarm with both the red button and toggle switch on the left. I have tried several sequences of on/off and locking the door. Any suggestions?
Sounds like it may be an aftermarket alarm if you have a toggle switch. I don't know any factory alarms that use toggle switches?
Most alarms are merely a circuit interrupt set that cuts the black wire to the switch. If you cannot get a FOB for it, take your lower dash off and CAREFULLY remove all traces of alarm setup. Return the truck to stock, and you won't have that problem anymore.
06-01-2021 01:51 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
