00 Tacoma Misfire
Old 06-09-2016 | 10:33 AM
Kelly Peterson's Avatar
00 Tacoma Misfire
Hello,
I have a 00 Tacoma 3.4 and it is throwing the following misfire codes, P0300, P0301, P0302. It runs great when cold and it even seems to run fine when hot, the problem is after a hot soak, it has a misfire that you can both hear and feel. It has all new Denso OE spark plugs, Denso plug wires, and Denso OE coils. When I changed the plugs I looked in each cylinder and none of the pistons looked washed like it was getting coolant in the cylinder from head/head gasket problems. Not sure where to look next, anyone have any ideas on things to check?
Thanks!
Old 06-10-2016 | 07:53 AM
vasinvictor's Avatar
In order of most to least likely. Bank 1 o1 sensor, dirty MAF, coolant temp sensor, crank sensor.
Old 06-13-2016 | 07:47 AM
Is there anyway to narrow it down? I can rule out the MAF for the most part as it was replaced with an OE unit a few months ago.
Old 08-02-2016 | 06:59 AM
For the record it was the fuel injectors.
Old 08-02-2016 | 07:01 AM
Thanks for updating. Glad it's fixed.
Old 08-03-2016 | 04:09 PM
fierohink's Avatar
There seems to be a rash of injectors checking out this summer, myself included. This will be my new go to diagnosis.
Johnboy80
11
07-14-2016 03:29 PM
alabamatoy
3.4 Swaps
03-19-2016 10:27 AM
bogginyota
03-18-2016 08:40 AM
yotanamedhelga92
03-12-2016 04:07 PM
nate91SR5V6
03-12-2016 11:39 AM
Quick Reply: 00 Tacoma Misfire
