xxxtreme22r's 1987 Pickup Build-Up Thread
Old 08-05-2012, 01:44 PM
  #1501
yotaluver's Avatar
Wow that sux, glad ya got it back up an runnin
Old 08-05-2012, 02:34 PM
  #1502
RBX
RBX's Avatar
I like the engineering, pretty cool idea. Glad to see you got the issue sorted.
Old 08-05-2012, 04:15 PM
  #1503
92 TOY's Avatar
I'm gonna buy a few CHIA Heads and spread the seeds inside your engine compartment
Old 08-05-2012, 06:44 PM
  #1504
xxxtreme22r's Avatar
SO far so good. Still running and pulling like a champ. Although I almost lost a wheel. 4 out of my 6 lug nuts on one of my wheels came all thje way loose and two weren't far behind on one of my wheels. I hope that's not a sign to come with these lug nuts and wheels.
As for the Silla, I still recommend it to anyone despite the ones giving flack for getting it. It's held up nicely. I do still overheat on occasion, but with the amount of mud I get on this thing, I can't fault the radiator. Hasn't cracked, leaked or anything like that when I hit the water with it.
The BB's seem to be doing ok for the most part as well for balancing the tires.
Old 08-08-2012, 02:12 PM
  #1505
Zelephant's Avatar
Cool! Thanks for the feedback. I ordered the identical radiator under a different name from GenesisAutoParts.com. I'm looking forward to seeing the improvement over the junky rad I have now.
Old 08-08-2012, 02:17 PM
  #1506
ChefYota4x4's Avatar
hahaha... TOTALLY laughing at myself right now... Just NOW got that... I read it the other day, and for some reason it just registered as "putting them in his engine"... But COMPARTMENT, YES! The first "22R-CHIA PET!"
Old 08-08-2012, 06:13 PM
  #1507
Why does the Chia Pet comment remind me of this:
Old 08-08-2012, 07:23 PM
  #1508
AHAHHAHAHAHA! ^^^^ EVERY TIME I see that I think of two lines.... "You sold your dead parakeet to a blind kid, Floyd????....... NICE WORK!" hahahaha... And "Hey, look, ..... I'M RUNNING REALLY FASSSSSSSSSST!" haha.. CLASSIC Comedy!
"Shhhhhhh, shh.... Just goooooooooooooo",
Old 09-04-2012, 12:10 PM
  #1509
well, not so good news. That rapping I had, yeah well.....
Found my cause. Hopefully no effect and my pistons didn't meet valves. I bet that's the master link that broke. So, when someone tells you it almost impossible for a 22r chain to break, you can call B.S. lol
Broken steel rail timing chain guide.
Broken "bright colored" master link.
That's not supposed to be there!!!!
See those two bolts? They did have heads on them when they went in!!!!
This WAS straight at one point!!!!
The bolt that is completely beheaded was somewhat loose. The other was still snug. Looks like this was rubbing for a while based on what the metal chain guide is telling me. Probably longer then I thought. hmmmmm
Good news is once I get this engine back together, it's coming out with the transmission and transfer case and this truck is getting sold. Yes I said SOLD. Got someone interested in it and if they don't attempt to talk me down it going for $500 without the engine and drivetrain. Wheels are staying and not sure on the tires yet.
However....... I have a live on an 83 single cab pickup with no drivetrain, 3" body lift and what appears to be a mild spring lift. For get this....$500. Almost like getting and even swap.
Old 09-04-2012, 12:15 PM
  #1510
irab88's Avatar
well that sucks.
by the way, i can't see your pics.
and what timing chain guide did you use? how many miles?
Old 09-04-2012, 12:16 PM
  #1511
<20k Engnbldr's kit. And photo bucket is being a PITA, none of the photos are showing up. Said they uploaded fine, but if you look at previous posts of mine, they aren't showing either.
Old 09-04-2012, 12:24 PM
  #1512
irab88's Avatar
yep, i was just noticing that. s'ok.
less than 20? crap, i've got 25 on mine. wonder if i need to be worried
Old 09-04-2012, 01:33 PM
  #1513
RBX
RBX's Avatar
I put one in my 2wd but only got about 10k on it. Guess I'll check it sooner then later.
Can't see pics either.
Old 09-04-2012, 03:26 PM
  #1514
yeehaw1's Avatar
I can see all but one pic...
That sucks man, and hate to hear that your selling er, but that 83 sounds SWEET!!!
Old 09-04-2012, 05:30 PM
  #1515
RBX
RBX's Avatar
Now I can see them. So looks like the tensioner went prematurely?
Old 09-04-2012, 07:46 PM
  #1516
Either that or the two bolts loosened up. Look at the tensioner video.
Timing cover is toast too :
BTW it's not fun working around all this mud. lol.
Take note what's missing, compare a photo of a new one if you don't see it.
Old 09-04-2012, 09:19 PM
  #1517
I'm really sorry, Brandon... What a.... well, concerning thing for MANY running this kit(Sounds like a freak/fluke thingy...But still, haha)... But hey, sounds like it'll work out like you'd like in the end, right? SFA Lifted lil 83 beast? MAN I miss my 83!
This has me curious as well. I have that kit and I ALWAYS seem to have, IMHO, a bit too much 'RATTLE' in the morn, if YKWIMean? After that, its' silent. Has me curious on the tentioner AND Oil pump. I have 2 toyota filters that've been on there now... and neither loses oil/fall back valve works. Course, I'm not SURE there's anything wrong with the oil pump...BUT, 2 motors now with the same pump, different crank and rods, new rings, clean pick up tube... And a sound like it's starving off the bat? NO LIKEY!
Old 09-04-2012, 09:21 PM
  #1518
WOW, did the chain come down and shave off the housing that goes around the cranks chain-drive gear?
I did what they said to a level of being obsessed about getting it right! haha... " Do NOT, UNDER ANY CIRCUMSTANCES overtighten the tensioner bolts beyond 12#".........
WTH, MAN ! ? ! ?
Old 09-04-2012, 09:31 PM
  #1519
Grego92's Avatar
dang sorry to see what happened...good thing I peeked at your thread. Doesn't the engnbldr kit come with an oem osk tensioner? I used a complete osk timing kit so still has me worried. I hope I torqued those bolts correctly...crap
Old 09-04-2012, 09:39 PM
  #1520
toyospearo's Avatar
WOW!
Sucks B.
I have access to TC covers and other 22r / 22re stuff. Let me know if you decide to fix it and if I can help.
Quick Reply: xxxtreme22r's 1987 Pickup Build-Up Thread
