xxxtreme22r's 1987 Pickup Build-Up Thread
Old 06-03-2012, 04:43 PM
  #1421
xxxtreme22r's Avatar
Nah, they aren't that rare really. And yeah I had considered the retreads before I picked these up with 90% tread on them for $400 with a spare.
The only thing with them is the fact that any "mud terrain" does good on the trails and light mud holes, but for these bogs, nothing beats either TSL Boggers or maybe even TSL IROK's.
Old 06-05-2012, 10:30 PM
  #1422
Just a little fun during a Memorial Day party.
http://www.youtube.com/watch?v=u-xaAsuv3F4
Old 06-06-2012, 08:02 AM
  #1423
Originally Posted by Good2bHere
This is very nice car but this car is damaged.
GTFO Spammer.
Old 06-06-2012, 08:21 AM
  #1424
ChefYota4x4's Avatar
"This is daytime, but the nighttime is coming....... errrrrrrr........ and then daytime again... Are you sure you getting enough vitamin? I can may be helps you! YOR IN LUK! RIGHT NOW, for a limited time............
OH, wait, must transition to alternate, relevant sales....I thought I was on the WebMD Blogs..... Ok, SOOOO, YOU, sir, like trucks...... Trucks are good... But this truck is need sumpthing! YOR IN LUK! I just happen to have.......... " Insert BOT picture of photo of Rahgbi, of Dubai, right here> .......hahaha.
AHHHHHHHHHHHHHHHHH! They're not even THAT clever, Brandon, eh? hhahahahaa.
Old 06-08-2012, 07:39 AM
  #1425
Truck was still acting up yesterday, had one hell of a time starting it and pretty much limped it to work. It wouldn't idle very well or very long. Opened up the hood and it started right up. I was like WT.... ???? Then while it was idling, I closed the hood and it shut right off. Ok. Guess it was just bad timing. After failing to start it again I opened up the hood, fiddled with some ignition wires and it started again. Close the hood, yup shut off......again. WT.....???? I did that sequence one more time, same results.
Wish I got it on video, but the security guard at work and another driver came over to give me a hand. I had been there messing with it at work for almost 45 minutes.
I proceeded to pound on the ignitor and moved the connector for the distributor some and it drove home fine. I hate electrical problems..... I don't have a spare OEM coil wire but the Crane ignition is wired pretty much parallel to the OEM ignition. Some rearranging connectors I can swap right back to the OEM ignition as long as I get myself a coil wire that fits the normal coil.
Not sure if the wiring problem is Crane, Distributor or Ignitor, but it's been like that for over a year without any issues till I damn near took the truck airborne twice while driving 35mph though an Industrial Park.
Old 06-08-2012, 08:00 AM
  #1426
RBX
RBX's Avatar
Brandon, it seems like something is contacting when you lower the hood, and shorting or arcing the system. Did you mention that? my reading comprehension is sub par these days.
Old 06-08-2012, 08:22 AM
  #1427
Yeah I pounded on the ignitor and moved that green connector for the dizzy and all was well. Not sure yet why that worked.
Stupid thing is, nothing under there has moved in over a year.
Old 06-08-2012, 11:55 AM
  #1428
U sure the pins on the connector haven't backed out? Mud on one or more of those could cause a lil POP, lol.
Old 06-08-2012, 12:09 PM
  #1429
RBX
RBX's Avatar
Originally Posted by xxxtreme22r
snip...
Exactly, it's not like the engine is constantly vibrating or being used as a subterranean test vehicle for soil composition. If the PA department of Agriculture every needs core samples you could save them some money and just scrape something off. (sarcasm)
Seriously though, my connector on the dizzy has two wires with exposed copper, I'd check the wire connections as Mark suggested. I still find it odd the hood closing turns it off. what if you shut the hood ever so lightly?...same result?
Old 06-08-2012, 12:12 PM
  #1430
Yep, same result, did that last night. Ran fine home last night, 'm afraid to go out there and check today. lol. I really wish I got that crap on video. At least y'all believe me. hahaha.
Old 06-08-2012, 12:22 PM
  #1431
racerflea's Avatar
Well lets not forget that the hood while shutting actually goes down a little further than it sits it sound to me like something is grounding on ur hood maybe u bowed ur hood in during ur horsing around or bent something somewhere
Old 06-08-2012, 12:35 PM
  #1432
That horsing around was actually on the road going 35mph.
But with the stupid dips in the road and not being on that particular road for quite a while, it felt like I took the truck airborne. I thought for a minute last night that I might have busted a body mount up front or something, but truck is sitting level.
Old 06-08-2012, 12:54 PM
  #1433
racerflea's Avatar
Could ur hood be jaring the carb? Does it have a liner that could be choking the engine out?
Old 06-08-2012, 12:56 PM
  #1434
Don't think it's hitting the carb at all. I'd see it with the amount of mud under there. I just went back out and idled it for like 15-20 minutes and slammed the hood shut after I put that green dizzy plug back on where it belongs and it's perfectly fine now.
Old 06-10-2012, 06:56 AM
  #1435
Old 06-10-2012, 08:46 AM
  #1436
RBX
RBX's Avatar
Two weeks left!
Old 06-10-2012, 08:47 AM
  #1437
I'll get it fixed by then. Got a set of old plug wires from itsbroke, and unhooked the crane system. Gonna see if it comes back, pretty sure with me idling it managed to show up again after idling for a while. Gotta drive it an find out though.
If it does, I am gonna pull the plugs and see if 1 or 2 are fouling out. Doubt it though since it's not really a dead miss, when it does it, it's almost like a 1000-1500 RPM rev limiter. And it reflects in the tach.
I wish I had a volt meter on this, I wonder if a voltage spike from the alternator would cause this as well.
On a side note, I really have to figure out what I am gonna do for a gas tank skid plate. I don't know how simple it's gonna be to lift the tank and make a flat skid under it.
Old 06-10-2012, 09:06 AM
  #1438
irab88's Avatar
c'mon... i'm done with my stuff. you should be ready by now
Old 06-10-2012, 09:11 AM
  #1439
Hahah this just started acting up. Now the skid plate on the other hand..... Should have been done, but got busy doing the whole 10 year video thingy.
Old 06-10-2012, 09:18 AM
  #1440
irab88's Avatar
excuses, excuses...
in any case, i'm needing new tires, so i'll be looking for some of those this week, as well
Quick Reply: xxxtreme22r's 1987 Pickup Build-Up Thread
