xxxtreme22r's 1987 Pickup Build-Up Thread
Old 02-01-2012, 06:26 PM
  #1281
toyospearo's Avatar
wow! I thought mine looked rough
Old 02-01-2012, 06:40 PM
  #1282
xxxtreme22r's Avatar
I don't know why the alternator went bad, nor do I know why the steering was binding up.
Ain't noone can say I don't have fun with this thing. lol.
Old 02-01-2012, 08:43 PM
  #1283
twistedyota's Avatar
wow, tht is funny. and i thought mine got muddy
Old 02-02-2012, 06:44 AM
  #1284
Lifted the truck about 1/2-3/4 of an inch in the front.
If I had to guess 50-75 lbs of mud/rock mixture. And maybe another 10-15 still on top of the front diff. ..... yeah I am gonna have fun taking that out once I get my rear 4.88 to match the front one I got.
Old 02-02-2012, 08:51 AM
  #1285
ChefYota4x4's Avatar
Dang, you must have a Bionic Stabilizer!!! lol. Nice job on the clean up.... Hope the repairs all go without drama!
Old 02-02-2012, 08:58 AM
  #1286
3mph Toy's Avatar
Originally Posted by xxxtreme22r
Had a helluva time getting the bottom alternator bolt out. Almost thought it was bent. Just mud I guess. Looks like it will get a good treatment of anti-sieze going back on. Couldn't get it out the top, so had to remove the skid plate. And I have never laughed harder in my life.
This is the way it came off.
As you can see, only about 10% of the mud came with it. Even has the fin marks from the skid plate.
WOW Brandon, using modeling clay to build some type of high performance mud deflector. VERY IN GEINIUS!
Old 02-02-2012, 09:06 AM
  #1287
3mph Toy's Avatar
I think I seen a sign just south of I-80 on RT-93, it read, "Clean Fill Wanted". Maybe you can help him out?? Or you better put that back from where you got it from, otherwise you they may not be able to hold more events there anymore... No mud!?!?
Old 02-02-2012, 09:52 AM
  #1288
Dang I was just down there by 80/93 too in Hazelton to pic this part up at the dealership. Oh well.
lol, Chef, that stabilizer is that Procomp one. Shock held up just fine, but well, as you can see slightly in that pic the dust boot didn't fair so well. But confirmed, I got the rest of my steering wheel travel back. What I thought was an issue with the gearbox / pump, was the stabilizer being well, hung up on a "little bit"of "mud".
Oh and yeah, confirmed, 90316-6004 IS the correct part number for that knuckle seal for the CV. Came to $67.69 for the set including my 10% off coupon and 6% sales tax.
I was planning on hitting the seals with some grease upon install, but they are already coated from the factory.
Old 02-02-2012, 10:52 AM
  #1289
Man, there's just a 'beauty' thing when it comes to how 'TOYOTA' does most things, including they're own parts, eh? lol.
Yeah, some of them could have been stronger to begin with(or updated, which they DO sometimes do), ...but compared to an S10 or something? PFSSSSSSSST! lol.
Old 02-02-2012, 11:00 AM
  #1290
Yeah, BIG confusion regarding the actual part number of this seal. Even Toyota lists the wrong part number for it.
Let's just hope I don't have to update that CV side seal, because I didn't order them. The ones on the "new" CV's are good. ...... for now. lol.
Old 02-02-2012, 11:54 AM
  #1291
3mph Toy's Avatar
Next time you go to Independence for parts let me know... A friend of mine is the parts guru there...
Old 02-02-2012, 12:00 PM
  #1292
Dang, now you tell me. I probably woulda saved more then 10%. lol.
Old 02-02-2012, 12:39 PM
  #1293
RMP8080's Avatar
Look at the bright side, your get better fuel mileage with the weight loss.....
Old 02-04-2012, 06:31 PM
  #1294
yeehaw1's Avatar
Went for another test drive. Only does it with the hub locked. Does not do it with driver's side hub locked in either 4wd or 2wd. Does not do it in 4wd with Passenger side unlocked. It DOES do it with passenger side locked and in 2wd. Acting EXACTLY like the drivers side when I replaced the CV and Spindle bushings. But completely different noise. Before it sounded like a rubber on rubber sound. This one sounds dang near sounds like a urethane/hard plastic gear grind noise.
huh, i think we got the exact same problem, though i would say mine sounds more stuck caliper-ish (but the caliper isn't stuck?) It definetly ain't a bearing, and mine does it wheather in 2 or 4wd hubs locked or unlocked..., but whatever it is ain't broke yet so idk, guess when it does i'll fix it...... If your knuckle seal fixes it, make sure to let us know lol
Old 02-04-2012, 06:40 PM
  #1295
rattlewagon's Avatar
Thats some mud!! haha.
Old 02-04-2012, 07:42 PM
  #1296
yotaman85's Avatar
thats insane. i avoid mud like the plague. it does nothing but get you stuck and distroy your truck while only being fun the first 2 times, or once every 10 years. although now that i live in TN i better get used to it...
Old 02-04-2012, 09:21 PM
  #1297
Nope, mine only does it with the hubs locked. I'll be changing out the knuckle seal, CV and the spindle bushing. These don't make noise with the hubs unlocked. If you have a noise like this with the hubs unlocked, I'd say they are the wheel bearings or....simply a rock in between the rotor and the dust "shield" which will sound very similar to a caliper/worn brake pad issue. I've had that issue before.
Old 02-06-2012, 12:43 PM
  #1298
Stupid cone washers !! That is all.
Old 02-06-2012, 01:01 PM
  #1299
Torch, BFBH, Pinpoint accuracy, nuts bolted to the 'plum'/'flush', 'BINGGGGGG'! lol. I know, your have many more factors back east/being a 'Mudder Aficionado'!
Best wishes, don't break anything, homie! ........esPECIALLY your fingers/etc! ..
Old 02-06-2012, 11:56 PM
  #1300
yeehaw1's Avatar
I had my dad check the wheel bearings last weekend (or he said he did anyway) and apperently theyre okay, i'll check for a rock tommorow (today), lible to have the front of the truck apart before the days over....
Thanks xxx, and best of luck with your cv's and etc.
Quick Reply: xxxtreme22r's 1987 Pickup Build-Up Thread
