ToyoTech559's 1988 4Runner Build-Up Thread
Old 04-17-2012, 06:38 AM
  #421
ToyoTech559's Avatar
Originally Posted by malteserunner
Let me know if you need the driveshaft. If the weekend works better for you, we can make arrangements.
I didn't know they had cardboard in them... Learn something new every day.
thanks. i know the newer ones have cardboard in them since one of the techs has cut one open. im pretty sure the older stuff has the same stuff in it as well. this weekend will work. could you text me the price. thanks again
Old 04-17-2012, 08:29 PM
  #422
vang_22re's Avatar
As of right now I don't know the price yet got to think about it. But soon haha
Old 04-20-2012, 06:49 PM
  #423
hahah ok.
well since i installed my elocker. after a few days i noticed a small leak. must be a combinations of stuff but i know for sure i used toyota black FIPG instead of the red. i have tons of black, used for resealing anything that has oil. red is for anything like transmission and/or sealing of stuff that uses gear oil. i got lazy and just went under the truck and tighten up the nuts and worked for a while but started to leak again. i noticed it was coming near the upper longer stud area. i went to tighten the nut on it and it started to pull the stud.
i ended up doing this at home (never again) back still sore... i dropped the third and found a stripped hole for the upper longer stud. i re tapped it and went to hardware store for a 5inch bolt. goal was to install the bolt from inside the diff but there wasnt enough room so i cut the head off and added threads since it wasnt a fully thread bolt. this allow me to install the home made custom stud further into the hole and i used a locking washer and nut on the inside of the stud to keep the stud from being pulled out. its much stronger now.
1st time i didnt use any gaskets, just black FIPG. this time i put some red FIPG on the rear diff housing than installed the factory paper gasket than applied some more red FIPG on top of that so the paper gasket is sandwiched in red FIPG. now the back killer, trying to man handled an odd 80lb 3rd member into the two long studs that was never perfectly straight to began with. sweating and cursing since i was racing against the drying FIPG. i finally got in on and bolted. just need to pick up the driveline tomorrow and get some gear oil. hope it doesnt leak and i fix the driveline noise..
oh and i giving it 2days for it to dry
Old 04-20-2012, 06:50 PM
  #424
oh i forgot. an update on how my gears look. im no pro but it looks like i set it up pretty good.
Old 04-20-2012, 08:01 PM
  #425
ChefYota4x4's Avatar
Yep, .....dem's HEAVY SOB'S! lol.
Nice job!
I used the paper Gasket and Red Yota Sealer as well... Not a drop in 5K. I'll bet it will be 100K, no problem.... worth a second hahaha.
Old 04-20-2012, 08:49 PM
  #426
vang_22re's Avatar
Dan that was a mission! Haha I just use the grey silicone with no gasket it's holding up pretty good no drips yet. Good luck on the drive shaft.
Old 04-20-2012, 10:23 PM
  #427
Yep, that works ok too, Vang.....
I used Permatex-Gear Oil Sealant, too... It's in a buddies rig I sold him... Been leak free for over 160K. The rear end, on the other hand? Yep, ..... after 368K, it's time! lol.
Old 04-20-2012, 10:24 PM
  #428
Toyo..... When is Pismo, anyhow? I know I just missed one not too long ago... right?
Old 04-21-2012, 09:22 AM
  #429
Nice job!
haha thanks.
gonna go in a bit to pick it up if adam is available
the most recent Toyota one was the Surf N Turf that i didnt go but i did go to the one before that. the Toyota jamboree. was back in November iirc
not sure of any up coming Toyota events at pismo but i do plan on going in a month or two with a few friends
Old 04-21-2012, 09:56 AM
  #430
malteserunner's Avatar
The next Pismo Jamboree is scheduled for the last weekend in September. We'll be there, for sure.
Old 04-21-2012, 12:27 PM
  #431
Ahhh, ok, thanks, guys.
Old 04-21-2012, 01:18 PM
  #432
got my driveshaft from adam. thanks again. now to switch the u joints over
i will to be at the next jamboree
Old 04-26-2012, 09:58 PM
  #433
runs-on-4's Avatar
Originally Posted by ToyoTech559
been a busy weekend for me i guess. finally got around to adding a factory 4.88 IFS diff in. used my non add tube. i have to say those that do this on the ground must have more skills than i do. i did this on a lift and still was alot of work...
4runner to pre-runner
top is ADD 4.88 diff. just have to remove the stubby gear thing. i had to pop the cover open to pop the stub out
once the stub is out. you can see it looks just like a non add diff. just need to install a seal.
the seal on non add diff are the same on both sides
installed and you can see the ADD sticker and a NON ADD tube
not sure when these bad boys will be installed. just went with HREW kickout from 4x
what do you call that seal. can i get one at napa or some place llike that or use the one off my current non add diff if it come out easily?
Old 04-27-2012, 10:46 PM
  #434
i wanna say its called an inner axle seal or differential output shaft seal. i got mine at the dealer.
IFS 7.5" front 3rd axle seals part # 90311-35032
i would get two and do both while you have it apart. i would also use oem since i have read others havent had good luck finding a non oem one that fit right
Old 04-27-2012, 10:49 PM
  #435
so i swapped the ends and ujoints of my original drive shaft and installed them on to the other one i got from adam. got it all installed and guess what. same thing. from what i was able to see while it was up in the air. it look like the drive shaft is not balanced. so im gonna get it balanced and see what happens. i dont know how this even started or what caused it.. oh well. going on another trip to bald tomorrow. wont be much snow but i need a break lol
Old 04-28-2012, 12:54 PM
  #436
vang_22re's Avatar
That sucks to hear hope everything work out.
Are you going to bald with the big yota family? Might be some more snow cause the of light rain we had. Not too sure tough
Old 04-28-2012, 04:08 PM
  #437
Mount Baldy? Or Bald Mount? lol.
Old 04-28-2012, 07:41 PM
  #438
blakefogt's Avatar
there aint nothin to do up in mt baldy homie! haha :p one road up one road down
Old 04-28-2012, 10:29 PM
  #439
super tired. reply to you guys tomorrow
leave you guys with this lol
Old 04-29-2012, 10:04 AM
  #440
cr@ves4wheelin's Avatar
Dang lol looks like it got a little sketchy there.
Quick Reply: ToyoTech559's 1988 4Runner Build-Up Thread
