Terrys87 88 Truck Build
#241
Hello junk4u..I have lucked out and got them to come off with different ideas. Sometimes you get one that just wont budge. I need to break down and buy one. My tools get on the list and every now and then I do make it home with one that I need. The right tool makes the difference from an easy job to a big job.
This month I'm looking to get the click torque wrench that HF carries and spec them with the craftsman (old one) and see how far they are off. The older craftsman tools seem better than todays craftsman tools. You can even pickup craftsman tools at ACE hardware now.
#243
LOVE HF! Totally agree with you, regarding the 'lifetime' and 'price that can't be beat for at LEAST a ''try'' ' end of things, Junk4u! I have a 1/2 Drive Impact, Chainsaw, 4.5" Angle Grinder... All with the lil extra 2yr unlimited warranty and got them all for HALF even what they usually ask.. NONE have given me a problem. Cordless Drill and LED combo kit, too
Terry... YES, I did add the 2nd Gen Maplight... All you do is remove your old one, cut along the sides for 1/2" or so(until the 2nd Gen one fits) and drop it in and bolt it up... the bolt holes are IDENTICAL, .... so now I have one that wont break off as easily on the 'lever' end of things... I SWEAR it seems brighter... might just be the way it's set up...but I think I'm just imagining things... No before and after pics.......... But here's one nonetheless>>>>
#244
Staff
Hello junk4u..I have some name brand tools and some Harbor Freight. I know HF gets put down sometimes and I have had a couple to go bad, but most have done what I needed for a lot less then the name brand. Some of the things I wouldnt have if I had to wait for a good deal on the other brands.
I just checked this months ad and I missed the torque wrench. On the front page too. I have the needle type and it has worked but the clicker type I am sure is more accurate. I will be picking that up tomorrow as I will be in town. Thanks for mentioning that.
Thanks Mark.. I am going to be looking into your light upgrade. I am very gentle with the lever. I have gotten them before and they break easily and I have broken them knowing how brittle they are.
I am going to pick up their palm sander as well. They have alot of things tha I want. I am using a nephews engine stand but is not the fold away and it is always in the way of things. I use it all of the time but it sure takes up alot of space.
#245
Staff
It was too hot to mess with the steering column so I waited til the evening to do something. Went to wire in a new plug for the clock and found 3 of the 4 wires. I am needing the red wire with the green tracer and unwrapped it to where I know the wiring hasnt been messed with. Apparently 88 uses a different wire as I have seen Toyota change a few wire colors from year to year. Not sure what year my replacement plug came from so will look at Mistys truck and see where the difference is.
Worked on some more trim pieces. They were stained even after giving them a good cleaning. The painted one was in worse shape then the unpainted one.
Wire from the 88 is missing the red/green wire.
I looked at my 85 and it has 2 red wires, one with a black stripe and one with a green stripe. The 86 is the same as the 85.
#246
eeerf why did toyota do so great with the parts being nearly the same year to year an then do that with the wiring?
heck tonight i was looking at the lady of the houses leaky 90 power steering box (one on the right) we replaced from a junk yard unit as i took mine off (also leaky, on the left) to descale the frame weld up the rusted out front support an also look into rebuilding it
her units bolt pattern to the frame is the same! even set her's in place an every thing lined up the steering shaft needs to be a bit shorter but if the collapsing slide is working should be fine (mines rusted solid an is in the cooking tank) the fluid lines are the same im thinking trying to find a newer used one or see how the rebuild kits are priced
sorry for hijacking terry
#247
Staff
Hello Cyberhorn..Dont worry about hijaking here. I dont mind at all, didnt even think it was hijacking. I did read somewhere that Toyota did switch gearboxs and seems like it was 88 or so. If I come across that thread again I will post it. There wasnt much of a difference. I learned one quick way to spot the difference is the casting is smoother on one then the other.
#248
http://www.sky-manufacturing.com/new...uct.php?id=175
#249
Since you guys were on the subject of steering boxes, I just thought I'd post this link to Sky offroad. I bought a IFS steering box through them several years ago (for $125, I think they're $150 now, but that's the cheapest I could find, not counting CL) they inspect them, check for leaks, and give them a 90 day warranty. I used mine with hi-steer on my old 83' never had a problem with it. Plus they come with the pitman arm,Just thought I'd post it up, hope ya don't mind Terry!
#250
Its looking great Terry! I love reading through your threads. There is so much to learn from a project like this. I am planning on tackling the body on my truck one of these days and your threads make it seem much more manageable. Great work!
#251
#252
Staff
I wasnt sure where I read it at, it may have been your thread. I am going to rebuild mine just for a learning experience. Every once in awhile I goof up and get it to work right on the first time.lol
#253
Staff
Thanks Ed.. I will keep them in mind. For what thye want at the boneyards here,you are better off buying new in some situations. Glad you posted it.
Just keep at it a little at a time and set a goal of getting something done at the rate that best fits you. No matter how small it is. It all adds up and will happen before you know it.
#254
Staff
Not much but I will settle for my goal of at least something daily. Maybe nothing in one day but two things the next. Got the door trims in. Not sure when he wants to buy some carpet, and the interior wont be to far from being done. Then later on will do the seats. You can see my failed attempt at trying to get the clock working. It was raining at the boneyard I like to go to see if they had a truck with the same wiring to see what I am missing. I have 3 of the 4 wires.
Just to let others see what I have been up to. I bought this 84 to fix and sell and it wound up having the frame rotted and plated. Not something I would want to sell for being on th road so am using parts off of it for this project and other things. It still has a future just not on the road. It is one I would like for 4 wheeling, but we just dont have any places around here anymore and not something I need to get into again just for the funds it would take.
I got an 85 Extra cab for a parts for the 84 as the PO wanted it off of his place or it was going to the crusher. Things turned around. The 85 is getting fixed when I come across a drive train and the 84 is the parts truck. Go figure. The 85 will be a good 6 months off before I really start in on it. It will be just a stock truck in good condition. I will be down to my 86 Runner and the pickup as we really need a truck around here. It is on the last few pages of my 88 Runner build (page 30) if you want to see it.
Anyways back to what little I did get accomplished. Trying to get the bed off of the 84 and some goof butt welded it to the frame. I spent and hour and a half getting one side broke loose and another hour working on the other side. Almost got it but me and doggie decided it was to hot to stay out so came in. Might try again later, but we are to get some storms soon.
#257
Staff
I am at a standstill on my 86 runner (funds) so I am going to get back on the truck. I have 3 sets of doors and all of the drivers side window regulators are bad. I am going to have to go to a salvage some distance away to get one and since the salvage isnt sure wich one it is I am prepping a set of doors with the wing glass and one set without the wing glass.
Here I am removing the lock for painting. If all goes well I plan on painting the cab Thursday or Friday. Still havent worked on the bed so it will be while. Had to sand off all of the old primer and will be getting it ready for paint in the next coming days.
A reference pic for putting it back together and how to get to it.
#258
Dude, ............ you are a MACHINE! lol.... My new name for you, "Terryminator"! hahaha.
Seriously, I watch your threads, daily, and I REALLY am getting a complex on how little I've gotten done! lol. I want to wire in the second deck lamp and rear window wiper cover dome lamp..... OK, I don't NEED to... but it would make me feel like less of a knob after reading your threads! hahaha. Wanna help me/walk me through it? You could duct tape the phone to your head(or bluetooth, whichever is better), and while you're working on yours, you could walk me through every step, each wire, every switch I'm wanting to add, etc... SOUND GOOD? ..........
#259
#260
lol at chef
oh if ya ever need new factory keys made as after a few years of making a copy of acopyof a copy they dont tend to work
passenger door lock has the key coded number on it take that # to the dealer an they can cut ya new keys for the locks or get one retumblered to match the others just FYI
