SAS'dToy's 1992 Pickup Build-Up Thread
Old 11-09-2006, 03:46 AM
  #221
tacoma728's Avatar
what's the prices on those?
Old 11-09-2006, 05:22 PM
  #222
SAS'dToy's Avatar
What kind of mileage are you looking for?
Old 11-10-2006, 03:53 AM
  #223
tacoma728's Avatar
less than 80, but could do ninety.
Old 11-12-2006, 04:30 PM
  #224
SAS'dToy's Avatar
I've got access to plenty of them then
here is my cell# 828-446-6749
Old 11-14-2006, 05:13 PM
  #225
SAS'dToy's Avatar
SHE HAS MOVED! I finally got around to moving my truck from the corner onto the lift! I mounted 2 of the tires on wheels and bolted them up to the rear axle and it will roll as long as the front is supported.
Here she sits on the lift now
I also assembled a dummy set of cases to mate to my R151F.
I also went ahead and put the new bearing on my MC 23spline input gear
I am hoping to go get the engine(again) tomorrow or Thursday. Now starts the daunting task of installing the 3.4 and trans/cases.
Old 11-14-2006, 05:40 PM
  #226
AH64ID's Avatar
Progress Progress Progress.....
Old 11-15-2006, 06:39 PM
  #227
SAS'dToy's Avatar
MORE PROGRESS! First I removed the old engine mounts(7MGTE) and ground off the slag from it and the old shock hoops. Next I removed the cab from the frame. I did this b/c it'll make the engine,trans and cases swap go easier. I AM GOING TOMORROW TO GET MY 3.4L!
Once I had the cab and frame seperated I pulled the frame to the front of the shop and set it up on jackstands
H1's make it so easy to remove a tire from the wheel
As soon as the weather clears up some I'm going to spray the bottom of my cab with SIMS(like Line-x but better)
Old 11-15-2006, 06:44 PM
  #228
91_4x4runner's Avatar
S/C'ed 3.4 or NA?
Old 11-15-2006, 11:31 PM
  #229
AH64ID's Avatar
what kind of camera do you have? Your pictures are almost always out of focus!
Old 11-16-2006, 02:38 AM
  #230
SAS'dToy's Avatar
N/A for the time being....
My camera...i dropped it a while back and now it does that.
Old 11-16-2006, 03:58 AM
  #231
tacoma728's Avatar
thanks, you must have some good resources with these engines. When can i give ya a call about those engines? I haven't been on here in a while, been studying and practicing to get my Class A license.
Old 11-16-2006, 08:57 AM
  #232
tacoma728's Avatar
yeah, looks like a lot of fun! I would love to have a place to do all that!
Old 11-16-2006, 10:48 AM
  #233
99_Runner's Avatar
I haven't checked on this thread in a while, but dang SAS'dToy, the rig is looking great. I'm sure that you had originally thought that you would be done by now, but as long as you do it the way that you want to and don't compromise just to get it rolling, then that's all that matters.
Again, great looking rig and awesome progress from a bare frame, 2 axels and an idea. :bigclap: :bigclap:
Old 11-16-2006, 06:58 PM
  #234
SAS'dToy's Avatar
I got an engine today! 68K miles...2000 Model Tacoma V-6 3400. I also picked up a R150F bellhousing so I can mate my R151f to it.
BLING! R151F Attached to dual cases with a clocked adapter!
And here they are in all their glory! 3.4L, R151F, Dual clocked cases. I already found them a home too!
Old 11-16-2006, 06:59 PM
  #235
SAS'dToy's Avatar
You can give me a call whenever....828-446-6749
Justin
Old 11-17-2006, 03:53 AM
  #236
tacoma728's Avatar
thanks, just need more than that 2.7
Old 11-17-2006, 08:41 AM
  #237
Ringmaster's Avatar
Damn! With the length of the engine/trans/transfer/adaptor/transfer, you almost won't need a rear driveshaft.
Old 11-17-2006, 08:48 AM
  #238
da_bigg_wigg's Avatar
Driveshafts are overrated
Old 11-17-2006, 09:38 AM
  #239
tacoma728's Avatar
yeah, that does take up some space.
Old 11-17-2006, 01:58 PM
  #240
SAS'dToy's Avatar
I don't really understand why you guys are flippin' out over the d-shafts...the only difference in my drivetrain and most of your is I added a dual cases. My rear d-shaft is only 4-5" shorter than a stock x-cab truck. My front is probably 7" or so longer than stock..just depends on how far I push it forward. I am going to try to start making my t-case mounts tonight
Quick Reply: SAS'dToy's 1992 Pickup Build-Up Thread
