RBx 1988 4Runner Build-Up Thread
Old 11-24-2011, 06:05 AM
  #881
RBX
RBX's Avatar
Same to you mark and everyone at yotatech.
Haven't been updating my thread lately cuz I have a project that is taking a bit longer then expected. Once it's finished, I'll be sure to upload some pics. The project is making a trunk under the bed "sunken box" to relocate dual batteries and OBA.
More to come.
Old 11-26-2011, 06:54 PM
  #882
ccannon222's Avatar
Cool build thread. I really like your rear tire carrier. Would it be possible for you to email me a pdf of the AutoCAD? If not, could you please post some pics of how your bumper mounts to your frame?
Chris
Old 11-27-2011, 12:27 AM
  #883
RBX
RBX's Avatar
Sure, pm me an email address. I am not sure if I have any pics of the frame mounts, I'll try to take some today.
Old 11-27-2011, 10:18 AM
  #884
RBX
RBX's Avatar
Washed and waxed. First time ever! Hehe
Old 11-27-2011, 10:37 AM
  #885
Cody91's Avatar
Looks Sweet
Old 11-27-2011, 10:55 AM
  #886
Outsane's Avatar
Purdy
Old 11-28-2011, 03:09 AM
  #887
RBX
RBX's Avatar
Thanks guys, i didn't realize how red my truck actually was, got to love single stage paint.
In other news...
get your Yotatech Calender Celebrating 10 enthusiast filled years, just in time for the holidays
https://www.yotatech.com/forums/f121...elease-245090/
http://share.shutterfly.com/share/re...Aas3Llo1YuGTsY
Old 12-08-2011, 06:06 AM
  #888
irab88's Avatar
https://www.yotatech.com/forums/f15/...2011-a-245811/
Old 12-16-2011, 03:07 AM
  #889
RBX
RBX's Avatar
Sunken Trunk
Been very, very busy lately, and finally got some work done to the rig last night.
Battery relocation, phase 1:
First things was to install a new rear cross-member since I want a box that clears the diff, and offers a fair amount of room. The cargo box the rusty(yet to be prepped) Crossmember sits on was in the back of my 92’ 2WD, which will be widled down to 20”x28” to sit in the floor.
Crossmember in
Time to cut the box, I love plasma cutters
Some clean-up and making the box collars, I want the floor to be just as rigid as before, and the angle will get welded to the floor and then the box dropped in from above to make a solid unit. This is also designed so if I decide later to install and auxiliary fuel tank in this location I can unbolt and lift the box out and just fill the hole with the lid I’ll make.
Cut the floor, and had to rework the exhaust
Dry fit
Installed the box, now I just need to build the lid to complete phase 1, phase 2 will be running lines to the front of the truck and dropping the battery in the box, then add the deep-cell
Old 12-16-2011, 04:17 AM
  #890
Swimmerboy2112's Avatar
Ahh I hate you and the awesome work you do!
Old 12-16-2011, 04:19 AM
  #891
irab88's Avatar
oh, that is sweet. i want to do that now.
looks like you're putting that toolbox to good use
Old 12-16-2011, 05:04 AM
  #892
RBX
RBX's Avatar
thanks guys
Yes Ian, i actually used the box in the back of the 92 for a while, but to be honest it just sat there, i never actually used it. Then one day while planning my attack for this project, i realized the box you gave me is the perfect depth....and then i took the plasma to it!
Old 12-16-2011, 05:33 AM
  #893
Outsane's Avatar
you are ridiculous!
just added to the must do list
Old 12-16-2011, 05:37 AM
  #894
irab88's Avatar
a few things:
- are you going to add a vent for gasses?
- insulation? especially with the exhaust right there
- when you do add the fuel tank, where will the battery go?
- i assume you're making a lid for it?
- got any pics of the underside?
seriously, i could easily make this work for the truck. nice work
Old 12-16-2011, 05:38 AM
  #895
xxxtreme22r's Avatar
I got some catchin up to do. Somehow I missed this box project. I am glad that a thread I started a while back regarding that spare tire cross member being important or not structural wise was good info since someone just cut theirs off.
Old 12-16-2011, 06:04 AM
  #896
RBX
RBX's Avatar
Originally Posted by Outsane
you are ridiculous!
Thanks, i try.
Originally Posted by irab88
a few things:
actually the box isn't air tight, but i do plan to seal it, and then add some vent lines. The compressor will live in this box also, so it will need some air-flow.
exhaust doesn't get hot back there, if anything i'd add a shield to the exhaust or wrap it.
IF, i relocate the fuel tank it will be for a fourlink suspension set-up, then the batteries and contents will relocate mid-ship in a new/different box.
yes, lid is coming.
i'll get some pics of the underside when i have daylight.
I installed the cross memeber(tacked it in place) before i removed the factory member just in case the frame wanted to move.
Old 12-16-2011, 06:09 AM
  #897
irab88's Avatar
dam. nice.
and i'm still trying to find aluminum welding in my area... (know anyone? )
Old 12-16-2011, 06:13 AM
  #898
JBurt's Avatar
That is pretty cool. Couple questions:
I assume the box will be under the carpet? Or are you going to have access through the carpet?
Are you going to sound deaden the box? I would be a shame to have a weak spot in all the sound proofing you did.
Did you put any corrosion resistance on the bottom of the box?
Old 12-16-2011, 06:22 AM
  #899
Zelephant's Avatar
The box is awesome, and it will be even more awesome with a lid! And I'm really interested in seeing how your dual-battery set-up turns out. I'd love a set-up like that! I'm looking forward to see what you come up with.
Old 12-16-2011, 07:01 AM
  #900
RBX
RBX's Avatar
dam. nice.
No, but i would ask a welding supplier for a recommendation
Yes under the carpet, i won't be getting int he box regularly, it's just not practical. Which is why i am putting things in there that don't really need attention.
The box lid will get the same treatment, the interior of the box will get some q-pads, but nothing major. The compressor will be in there, that would be the only reason to deaden it IMO.
every surface that has been cut, welded, ground or scratched was POR-15'd , then where applicable i used 3M paintable undercoating on the outside of the box and under the truck. I also seam-sealed the box collar to the corrugated bed to help reduce moisture invading the interior during a quick dunk.I will also seam-seal the inside of the box, install a drain-plug, and vent the top of the box(not lid) with a few holes or possible breather lines up to the top of the tail-light cavity.
thanks
Quick Reply: RBx 1988 4Runner Build-Up Thread
