RBx 1988 4Runner Build-Up Thread
Old 10-12-2011, 07:37 AM
  #841
irab88's Avatar
cool. i just meant your disc-swap, not the e-brake. but yeah, bring the caliper, i'd love to see how it could be interfaced
while there are a bunch of mods i want to do, i'm seeing now that i only have a few months of school left. so i'll just live vicariously through the mods of everyone else for now
Old 10-19-2011, 04:17 PM
  #842
RBX
RBX's Avatar
Just a video from this weekend
http://www.youtube.com/watch?v=y1rXMCvjdy0
Here is the thread
https://www.yotatech.com/forums/f100...n-pics-243255/
Old 10-20-2011, 08:24 AM
  #843
tj884Rdlx's Avatar
wow man. this is a great build thread. i started reading the first couple pages, then skipped to the last couple pages, and now i feel dizzy from reading too much with the wrong glasses and i have to take a break.
it's kinda creepy that you've done a bunch of things i'm in the middle of, or have just finished, or is still on my to-do list. nice to see some of my "wonder if's" already completed here, and with some dang fine quality. really great work here man.
i'll finish reading this thread when i can, then maybe you can answer a few questions for me if the answers aren't already in here.
i'm wondering how that deadening material is working for you, with the soft top on. did removing the hard top eliminate the benefits you gained from all that foil absorber material you put down? should i even bother? or, did you consider mounting your canback racks more toward the back? my soft top doesn't yet have slits in it, so i could mount like you have it; or i could turn the side rails 180* so the mounting tabs are to the rear. then i'd be able to access a basket by standing on the tailgate. i'm thinking do it that way so i can put a spare up there and avoid a rear tire carrier.
i read you were installing a 5 channel amp. i'm in the middle of that right now! who uses 5 channel??? i can't wait to finish reading how that worked out.
22 pages. wow, can't wait to get back to it. thanx for posting; happy trails!
tj
Old 10-20-2011, 11:06 AM
  #844
RBX
RBX's Avatar
Thanks for the kind words TJ.
The sound deadening works very well, however the can-back top gives more wind noise and traffic sounds as well. I don't run the soft-top all year, so the hard-top will be going back on very soon, and i can say it is a big improvement.
Can-Back was bought used, and that is the way the PO mounted it. While i think it would look better mounted towards the back more, the weight is more evenly distributed when mounting it closer to the cab. Plus, i can mount lights on the front of the basket if i want. I can stand on the tailgate to access the basket, but i need to climb onto the tires if i want to reach the front of the basket.
5 channel amp...front right and left, rear right and left, plus one sub channel = 5. I think my stereo sounds better outside the truck then inside.
Old 10-20-2011, 12:13 PM
  #845
richf's Avatar
Your trip looked fun. Wish I had something close to me like that. BTW what was the name of that cheap sound deadening?? Was it peel and seal?
Old 10-20-2011, 02:03 PM
  #846
RBX
RBX's Avatar
I used the foil base duct wrap found at home depot, and roof butyl which comes in an 8" roll iirc.
Old 10-22-2011, 07:05 AM
  #847
Staff
Terrys87's Avatar
Just doing some catching up. Everything looks great as always. Keep up the great work.
Old 10-22-2011, 12:25 PM
  #848
ChefYota4x4's Avatar
STUPID DOPE RIG! lol.... Seriously, RB, ..... keep it up, it's looking fantastic! Great videos/Pics!
PS> Is that Kodiak Disc 'E'-brake get'n slapped in there?
Old 10-23-2011, 11:04 AM
  #849
RBX
RBX's Avatar
Haven't fabbed the ebrake bracket yet.
Did this before going to George Washington National Forest(pics soon).
Spoiler from a 2nd gen 4Runner, pre brake light.
Rack , 200lbs rating, late 90's Blazer.
Old 10-23-2011, 11:06 AM
  #850
csc89's Avatar
What did you use to cut the perf. Alum? Sweet build. Pretty inspiring stuff
Old 10-23-2011, 11:22 AM
  #851
RBX
RBX's Avatar
Thanks guys for the kind words.
I use a jig-saw, dremel, file... to cut the perforated aluminum.
Old 10-23-2011, 11:05 PM
  #852
JBurt's Avatar
So is the rack from the blazer so you can use your basket with the hard top?
Old 10-24-2011, 03:08 AM
  #853
RBX
RBX's Avatar
^^^ That's the plan.
Old 10-24-2011, 03:39 AM
  #854
RBX
RBX's Avatar
Posted Some pics of my trip to George Washington National Forest in the Lee Ranger District near Edinburg, Va.
https://www.yotatech.com/forums/f100.../#post51807793
Old 10-24-2011, 09:36 AM
  #855
Hey, .... any write up/pics of the blazer rack install????
PS> What will your weight capacity be, curious. I would think it would be minimal since the rails of that rack are plastic, right? There's a guy on here with a great write up that built his own rack, etc., ....and he used box tube steel mounted through the hard top...(I'm not downing your plan.... I think it's a GREAT idea, and very good improv... it just inspired me to look up his link which I've bookmarked, lol.... Just curious what your new apparatus can hold.... on top of a rack basket. I'll be watching GREAT JOB!)
Old 10-24-2011, 10:02 AM
  #856
RBX
RBX's Avatar
Mark,
The rack is aluminum, and the ends are plastic. I basically took it apart, measured and cut the rails to fit between the rear windows and a few inches shy of the front and rear of the cab. Marked and drilled the holes thru the fiberglass top. Used stainless bolts, some sleeves on the bolts as to not deform the fiberglass when tightened down, permatex as a gasket, then made a plate on the inside. The plate is just 1/8" aluminum with two holes for each end of the rack to secure and spread out the load forces.
After a road trip recently, the rack is basically silent, but i haven't added the basket yet, and probably won't this winter. The basket looks cool, but kills mpg.
there, how's that for a write up? j/k
Old 10-24-2011, 10:08 AM
  #857
That's SICK! lol.... Ok, now, ....PICS! Hahaaaaaaaaa, didn't see that coming, eh? lol.
JK, I've been looking for a spare shell for a reasonable price... Found one on LA CL for 400$!!!!!! hahahahahahahaha. Yeah, hilarious... One was 75, but pretty tattered in the liner. I'm not havin none-o-dat! lol. If I find one with gray tone and that's clean/good moldings, .... I'll drill out mine as the liner has a couple lil holes in it. But vice versa if the other is bad, and then I'll just do my own liner! lol. We'll see, ya know?
I'm off to FAMART Welding right now.... HOPING it works out! We'll see(yeah, ...lot's of 'we'll see' for me lately, eh? lol)
Old 10-25-2011, 06:46 AM
  #858
RBX
RBX's Avatar
Aisin Master Cylinder Rebuild Kit sources
So i think my squishy brake issue is due to a faulty MC. I got the MC from '93 T100. While it was better then the original i pulled from my rig at the time, it is slowly failing and i'd like to rebuild it.
I have searched Hi & Lo, and I'll be damned if i can find sources for a reputable rebuild kit...Aisin, Altrom(sp?)
Anyone have any suggestions? Buying a remanned MC is way too much money, IMO, especially when i can rebuild the MC i have.
Thanks
Old 10-25-2011, 02:24 PM
  #859
No NAPA kit, eh? They had an Altrom for mine,.... but yes, that one is not mine, hahaha.
Not sure... have you tried dealerdirectparts.com? Call them, don't bother fishing around the site... There's one guy there who is REALLY knowledgeable.... can't remember his name. BUT, most of them will call the tech-dept. and get a solid answer on part numbers, etc., if it's available OEM, ya know? Plus, OEM is more, yes, but might even be cheaper than Altrom from DDP.com, ya know?
Old 10-26-2011, 03:00 AM
  #860
RBX
RBX's Avatar
i hate calling places, but that is a good idea since i didn't see it on their site.
thanks
Quick Reply: RBx 1988 4Runner Build-Up Thread
