RBx 1988 4Runner Build-Up Thread
#821
Ordered a Kodiak mechanical caliper today. Should be here the end of the week, then I need to get a rotor. The rotor should be the easier part of this equation.
#822
SCORE!!!!!!!
Surco aluminum Roof-Rack or Roof-Basket or Cargo-Rack...whatever you want to call it.
$32 bucks at the Pick'nPull
#825
now you know who is taking all the good stuff
#826
I haven't mounted it yet its just sitting there.
Actually, i went to the yard just because i hadn'y been in a while and there were a few small things i could use. However, not one Yota truck, not even a 2nd gen Runner in the place. Then i spotted the rack on top of a minivan. took a prybar to the factory rails, and worked it loose.
thanks guys
thanks guys
#827
RMA,
The not sure what you mean. My Can-Back has the bars tied into the frame and then i will mount the rack to the CanBack crossbars. I'll snap some shots of the interior.
thx
thx
#831
Rear Window Wiring Mod
While i was vacationing this summer, my rear window failed to roll down. I have the soft top on and always forget to lock the tailgate until i am driving down the road. I will put the rear window up enough to lock the tailgate, then put it back down. I also defeated the Cover Top switch, as described be 4Crawler.
After further inspection i found my computer was compromised by moisture, and the Power Window Relay computer, was not reliable.
Here is how i bypassed the computer using two SPDT relays:
Note:
I have been modifying some wiring on my rig, and try to update a wire schematic so if i need to troubleshoot, i can refer to the above drawing, once i have forgotten what i did 'x' years ago. Which is why you see the factory wiring mixed into the modified schematic.
Note:
#834
Replaced my Ilder Arm yesterday, solved most of my slight shimmy in the front. Next will be the Pitman Arm and then the wheel bearings.
My front brakes a still a bit sloppy after changing the pads and rotors Monday. yesterday i picked up new front brake hoses, hoping that the old hoses are expanding and creating the slop. I that doesn't solve the sloppy feel, i am stumped since the only thing i haven't replaced is the dual diaphragm booster.
#838
Not really a kit, i bought the caliper and will need to mount it to the t-case. I have a concept that should work by using the stock e-brake cable(front half) similar to the sky/trail-gear, but not as bulky.
#840
no you wont see it this weekend, cuz i don't have it mounted yet, i may bring the caliper though, so we can have some camp-fire brainstorming.
