RBx 1988 4Runner Build-Up Thread
Old 05-13-2011, 05:09 AM
  #381
irab88's Avatar
daaaang! i love the style the gussets give it. can't wait to see it installed!
(wanna build one for me?)
Old 05-13-2011, 05:10 AM
  #382
irab88's Avatar
Originally Posted by Zelephant
If your still looking for paint ideas:
[img]
You may have already seen that, but it's still a cool truck.
Nice progress on the tire carrier. Do you plan on carrying anything else on it, like a hi-lift or gas can?
uuhh...
https://www.yotatech.com/forums/f199...l#post51717266
Old 05-13-2011, 05:46 AM
  #383
Zelephant's Avatar
Fixed!
Old 05-13-2011, 06:06 AM
  #384
S.Skinner's Avatar
ok, so what your tellin me is i need to buy some stock and after my engine is done, come over?!?!?!?!? lol
Old 05-13-2011, 06:10 AM
  #385
irab88's Avatar
ha, yotatech bumper build day at rb's!
Old 05-13-2011, 06:25 AM
  #386
RBX
RBX's Avatar
The hard part is design.
I went thru many design ideas before i settled on this one. The tire swing out should be a bit future proof in my opinion. The tire will get a new home on the carrier, then fit the jerrycan(s) holder, Hi-Lift across the too and relocate the license plate.
This application is using a lite gauge steel, i figure if it bends i can bend it back, and if it fatigues i can gusset it more, or replace it with a new heavier design. The bumper is almost ready to be fitted to the truck so i can take final measurements of the swing pivot placement.
Barter:
I need more welding practice, so if you guys buy the steel(supplies), I'll weld up whatever you like. in exchange you will do something to my rig as payment/trade, of course we would need to come to a mutual agreement on what was fair. I am serious about this part because i need more stuff done to my rig then i have time for, i have a journal i carry with me with ideas and lists of mods...it is endless.
thanks for the kind words.
Old 05-13-2011, 06:57 AM
  #387
irab88's Avatar
i'm up for that offer. pick a weekend. got any wiring you need done?
Old 05-13-2011, 07:09 AM
  #388
RBX
RBX's Avatar
^^^Battery relocation! The fuel tank and tranny should be out of the way for you.
The batteries are getting mounted in a steel box just after and above the diff. I'm going to try to get some of that stuff fabbed up this weekend.
Old 05-13-2011, 07:32 AM
  #389
irab88's Avatar
so that's why you built the tire carrier- to make room for the batteries... ah-ha!
i'm working on my electrical this weekend, but yeah, lemme know if you got one free
Old 05-13-2011, 09:42 AM
  #390
RBX
RBX's Avatar
Yep, i usually have a million ideas i want to do, but most need to be done in a specific order....Body lift...easier to swap transmission, run battery cable...then fuel tank lift...then drivetrain... so yeah, the spare neede relocation, plus there is a good amount of usable space under the rig now that i added two inches.
should be picking up my Jerrycan this weekend, so i can make a mount for it.
I will pm you to get some details ironed out.
Old 05-13-2011, 09:56 AM
  #391
RBX
RBX's Avatar
here is the proposed idea:
I'll add some cross support, and would like to hinge it so i can pivot it down for service/battery change, then swing it up to bolt into place easier.
Old 05-13-2011, 12:38 PM
  #392
irab88's Avatar
(more on my build thread)
Old 05-15-2011, 07:22 AM
  #393
RBX
RBX's Avatar
so i deleted the egr and pair system yesterday, since all my other plans were foiled.
anyhow, anyone know why i would have abnormally high fuel pressure? she usually sits around 40-50psi and now reads 70-80psi. i have cracked the fuel line open to release pressure, but it jumps back upon ignition.
i have double checked and rechecked all my vacuum lines, and blocked off the throttle body ports, all solid connections.
i guess next is to test the fuel regulator switch.
thanks
Old 05-15-2011, 07:27 AM
  #394
S.Skinner's Avatar
what other plans were foiled? Is it raining up there? Little grey, but clear here so far.
  #395
RBX
RBX's Avatar
BTW i made sure the regulatr and VSV are hoked up correctly
Old 05-15-2011, 07:32 AM
  #396
S.Skinner's Avatar
ahh ha, but were you holding your tongue right when you checked it?
Old 05-15-2011, 07:52 AM
  #397
xxxtreme22r's Avatar
Is there a return line on those EFI trucks? Maybe it's blocked somehow not allowing the regulator to bleed off pressure?
Old 05-15-2011, 08:48 AM
  #398
RBX
RBX's Avatar
When I opened the return line a few drops came out, and I could here it drain down toward the tank. The fuel pressure never changed.
Old 05-16-2011, 04:17 AM
  #399
RBX
RBX's Avatar
^^^yes
i was gong to get a 5spd from crazy ray, but no dice. then i was going to do the ISR mod, wrong size couplings....fail.
just tested the VSV, and it checks out at 38ohms, FSM says 30-50ohms...so that is good.
Old 05-18-2011, 03:41 AM
  #400
RBX
RBX's Avatar
She still won't start.
The symptoms seem like a vacuum leak, but i'll be damned if i can find a leak. Tonight i will plug every non essential vac line and go from there...
Plan B:
I'm going to hook it all back up again and go from there.
In other news....where the hell are all the r150f transmissions? I scoure craigslists everyday. Junkyards want more then the trans is worth and they don't negotiate...
rant over..
Quick Reply: RBx 1988 4Runner Build-Up Thread
