Melrose’s new project: “Half Full”
#221
Stripes look great, bumper does also. Pretty soon you won't be able to call this the goo Runner any more.
The following 2 users liked this post by coryc85:
Damion812 (07-05-2024),
Melrose 4r (05-30-2024)
#222
Just fueled up the GooRunner and checked gas mileage. Last tank was mostly highway. 179 miles/9.17 gallons = 19.5 mpg. A new personal best for this rig with automatic trans. 👍🏻
The following users liked this post:
Damion812 (06-28-2024)
#223
Just fueled up after the weekend 228 miles, lots of it highways between Boston and CT.
10.5 gallons = new personal best of 21.7 mpg. Pretty satisfied with that!
surf13 (07-02-2024)
#224
At this rate you'll be at 30mpg soon. I think I got maybe 21 mpg once on a road trip.
#226
Cruising Between 65 and 70mph
I had a thought about trying to turn off 1 injector at sustained highway speed. I know GM did this with some v8’s in the late 80’s but don’t know if any mfgr is still using such a scheme.
Anybody think it would improve mpg?
#227
my 2nd '87, which now has 275+k miles, had a complete engine rebuild at 244k miles. with the 5-speed, i consistently return 22 to 24 mpg during the summer, with highway speeds of only 65 to 70, and secondary roads at 50 to 55. if i drove an entire tank on secondary roads, cruising at 45 to 55, i would expect to hit 25 to 26 mpg. my last tank (filled up yesterday) sat at 22.4 mpg.
my 1st '87, which sits at 227k miles, has an untouched engine (other than basic stuff and a head gasket). during the summer, at best i return 22 mpg, and more often hit 20 to 21. winter is 17 to 18. same transmissions and gearing in both. the difference is the rebuilt 22re is tight and has slightly more power (pistons are one size larger) and the valvetrain is new, etc.
Damion812 (07-06-2024)
#228
it would be difficult to turn one off, as they are all wired together to fire at the same time. that, and i doubt you'd see better mileage running on three cylinders. better mileage can be attained with an engine rebuild.
#229
sounds like the motor is in good order (it likely has fewer miles since rebuild than mine now does - 31K). i assume you have the same axle gears i have - 4.10s. otherwise, if you have 4.56s, that might be why you get a little bit lower mpg.
i get the 24+ mpg when running the 235/75r15s, and very close to that when running the 31x10.5r15s. i just swapped in my 32x11.5r15s/wheels, so the mileage will go down a bit, even with the odo correction. on the other hand, it's nice to cruise the highway at 70 mph and less than 3k rpm.
#230
I feel bad mentioning that we only put on maybe 80 miles last week heading out to Windsor Locks to meet with Alex then to Pomfret. I can only imagine what kind of mileage Alex put on!
#231
#232
Spent some time under the Goorunner finishing the hitch install. Just drilling a couple holes in the frame and socking down all the mounting bolts but now it’s good for mounting a bike rack and yanking on. Maybe i will work on making the snorkle actually snork next.
#233
with the auto, i think 22 mpg is pretty good. the slightly lower gears (4.3) will make it hard to get a lot more out of it. 5th gear, and the 4.1 set, allows the manual transmission version to coax that little bit better mileage. if it were me, i don't think i'd try to shut down an injector.
#235
if alex was in his 1st gen, he probably enjoyed it. of all the vehicles i've owned, i enjoy distance driving the most in my 1st gens (strange, i know, but i do). better than the accords i've had, better than the subaru or corolla, better than the camry, and far better than the volvos. most of those got better gas mileage, and all but the volvos could go farther on a tank of gas, but i like the driving/seating position best in the 1st gens (the second accord could do 600 to 620 miles on a tank (and i did so on multiple trips).
Damion812 (07-10-2024)
#237
Goorunner being an adventure vehicle today.
Kayaking on the Ipswich Rivah, lunch and a stop at the farm to restock on corn.
#238
More summer adventure for the Goorunner!
My son and I pointed the Goorunner North and in less than two hours were in Thornton NH to take a ride down the Pemigawasset river.
Since it was Monday, we basically had the river to ourselves.
Ready for launch
Down the road, a nice curated collection on display.
Some attractive pieces of yard art.
Ready for launch
The following 2 users liked this post by Melrose 4r:
4Runner4Leon (07-31-2024),
hurricanes (08-11-2024)
#239
A little farther up the road in Lincoln, NH we stopped at one of our favorite attractions, Hobo Railroad. We knew the restoration of the famous “Flying Yankee” train had stalled but were surprised to see it loaded on flatbeds, about to roll! We learned it’s moving to Conway NH. Hopefully it will be completed there and run again some day.
#240
Next, we took a ride down rt. 112, the Kancamagus highway. Since we live at about 100 feet above sea level near Boston, I wanted to test the altimeter. At the highest pass the sign says 2855 ft and the altimeter said about 2900.
Seem to work fine. Not Pikes Peak, but we’ll take it.
Goorunner ran great. Turn off the o/d for climbing mountain roads.
Then we got back on the highway for the boring drive home.
280 miles round trip for the Goorunner!
The following 6 users liked this post by Melrose 4r:
coryc85 (07-30-2024),
Damion812 (07-30-2024),
hurricanes (08-11-2024),
old87yota (07-31-2024),
and 1 others liked this post.
Luvtoyota
08-05-2022 12:20 PM
arlindsay1992
266
03-05-2021 03:12 AM
