lower fan shroud missing
Agree with Millball. However you will probably never miss or need it. The full shroud creates vacuum helping pull in air to cool the system down, you still will have enough cooling ability for normal driving. It was probably never reinstalled after a repair, unless the fan is off the vehicle, you can not remove the full shroud. The bottom piece has small fasteners that attach to the upper. You can buy after market shrouds.....
Patrick Kissman
10
06-09-2021 02:53 AM
Siahsiahpapaya
04-15-2016 12:03 AM
