irab88's 1993 PickUp Build-Up Thread
Old 07-03-2012, 04:51 AM
  #1901
irab88's Avatar
and at the other end of the same street:
(taken yesterday evening, 3 days after the storm, and it's still there this morning. a few neighbors are still running gennies, and i'm still lending power across the street and yard)
Old 07-03-2012, 11:14 AM
  #1902
ChefYota4x4's Avatar
Good Grief! Glad you're ok, man! I heard SO MANY guys from your area/and surrounding that were just FUMING how long everything was taking.... One guy said, "I'm in Virginia, ....and I have buddies serving ministry in 3rd World Countries that have power back sooner after worst storms!!!.... That's what we get for putting 18 panels under the workers who get it done! EVERYTHING takes longer with public unions!" hahahahah... I AM NOT dogging all public Gubbament sectors, Ian.... Just this guy... He made me laugh. lol... He had a good sense of humor about it.. But kind of a "C'MONNNNN ALREADY" stance on it? hehe.
Again, GLAD YOU'RE SAFE AND THAT YOU HAVE JUICE!
Old 07-04-2012, 05:53 PM
  #1903
irab88's Avatar
well crap
my transmission now sounds like a jackhammer (a quiet one, but a jackhammer nonetheless)
i was trying to merge, no one was letting me in (~35mph) so i hit the brakes and downshifted to 3rd to get in behind them. the drivetrain sounded like it just hit a rock, and about a mile later, the jackhammer noise started. i checked all the driveshaft bolts and spun it by hand, so i know the sound is coming from the transmission. later, i'll drain the tranny and inspect, but now i'm on the lookout for a new trans. oh joy.
Old 07-05-2012, 12:46 AM
  #1904
Originally Posted by irab88
well crap
Me 2! Well, I'm still able to shift it into 4th and it's quite as heck when cruising/under load/other than that GRIND FROM HELL, haha...... But that 'GRRRRRRRT' grind into 4th on occasions can't be good... I just wonder if/when it's going to cause too much metals in there and grenade the thing unexpectedly... WOULD LOVE to find a Turbo Manual Trans(R151F?)... but SO RARE, and never cheap, even used.
Best wishes on whatever you do, ... I'll be watching
Old 07-05-2012, 03:13 AM
  #1905
irab88's Avatar
nope, this is "all noise, all the time" no matter the speed or load. of course the rate changes with wheel rotation, and the noise varies with load/gear position/speed/etc, but it's always there. and i was sooooo close to 200k (i'm sitting at 199919).
that's ok. i have a line on an awesome drivetrain setup, so we'll see.
Old 07-05-2012, 03:26 AM
  #1906
RBX
RBX's Avatar
Sure it isn't the clutch? Or throughout bearing. You worked that clutch pretty hard at RC.
I've only heard Trans making grinding noises, not jack-hammer like sounds.
Old 07-05-2012, 04:56 AM
  #1907
irab88's Avatar
it's not the clutch or anything to do with the clutch. the noise "turns" with the wheels, not the engine. i can coast to a stop (clutch in or in neutral) and the noise will slow with the truck
Old 07-05-2012, 07:17 AM
  #1908
irab88's Avatar
gonna be replacing this:
with this:
soon-ish. picking it up this weekend
Old 07-05-2012, 07:24 AM
  #1909
RMP8080's Avatar
Ian, 2speed transfer case? Great way to go. Are you taking the old transmission apart to see what the problem is?
Old 07-05-2012, 07:38 AM
  #1910
irab88's Avatar
probably. i'll drain it tonight and see what falls out
r151f-2.28-4.7
Old 07-05-2012, 07:49 AM
  #1911
4ever4running's Avatar
Damn Ian, sorry to hear about the transmission issues...big repairs like that are never any fun...Looks like you found a pretty nice replacement though.
I got lucky with my transmission because the PO replaced it right before I bought it. I found a receipt for a transmission replacement in the glove box when I bought it.
Old 07-05-2012, 08:21 AM
  #1912
irab88's Avatar
heh, it's all right. i've gotten used to big issues happening. and really, it won't be all that hard, as i've done it before with the clutch replacement. the only thing that worries me is getting all the shifters to line up. i'm planning on doing quadruple-sticks on top of the block-off plate on the trans (rear-disco, 4.7, 2.28, 4wd).
Old 07-05-2012, 12:03 PM
  #1913
So you paid for that trans and need to pick it up, right? It's an R151F? DAYUM! I've been looking within 100 miles of me for a while! No luck.... Well, the occasional shop saying, "1500$!!! CHEAP, COME GET IT!!!" hahaha... But not private that I can find. Great find, Ian, congratz!
Things gonna be a beast!
Old 07-05-2012, 12:13 PM
  #1914
RBX
RBX's Avatar
I think that's gonna require a custom console...looking forward to this addition.
Old 07-05-2012, 01:44 PM
  #1915
RMP8080's Avatar
r151f-2.28-4.7
Nice setup, and you planned all a long......
Old 07-05-2012, 04:19 PM
  #1916
irab88's Avatar
definately not 100 miles away... more like an all-day event (3hrs each way)
i'm workin' with davez and radesigns to see if i can make a forward-shift tripple-stick setup. i wanna keep the console. all my stuff is in there, what am i gonna do, move it?
uuuuh... yeah! exactly!
Old 07-07-2012, 04:54 PM
  #1917
irab88's Avatar
some pics of the trans in the hanger...
advance adapters 4.7 housing
where the linkages will go
reverse sensor (i think)
neutral switch?
gonna have to convert the cable-driven to electronic spedo
and the rear disconnect. it's nice and smooth
tomorrow? put it in the basement!
Old 07-07-2012, 05:30 PM
  #1918
Wow, ..... BEEF! Nice find, Ian... congratz, man
Old 07-08-2012, 05:34 AM
  #1919
RBX
RBX's Avatar
Wow, nice.
First sensor on the transfer is your 4wd indication light switch.
Do you have the cable driven speedo sensor? You can mate it to your electronic speedo, there are threads around, or by a sensor from marlin.
Trans will have a reverse sensor and neutral, two different.
Old 07-08-2012, 07:23 AM
  #1920
irab88's Avatar
yeah, i was planning on using marlin's sensor. seems easy enough to add in.
also, moved the trans to the basement to work on it. it may be low head-room, but it's nice and cool
pro tip: furniture dollies work wonders under trannies
so that's my project for the next week or so
Quick Reply: irab88's 1993 PickUp Build-Up Thread
