irab88's 1993 PickUp Build-Up Thread
#742
That will be nice. What material are you using to make the end cap? Lexan is easy and cheap. You can heat gun it and bend it into shape, then you could easily add holes for switches or accessories on the end cap if you wish later. I use the yellow cpvc glue found at home depot to volcanize lexan to the yota plastics or itself, btw.
#749
2x16 lcd display and 2 led indicators is what i was going for. i want to put an arduino in sometime, but not for a while. these guys make some nice displays:
http://newhavendisplay.com/
anyway, is this normal? (remote temp sensor pointed at the t-case shifter)
#751
so i went up to see xlaxx this past sunday. he's got a nice 4runner now. his undercarriage is cleaner than my interior. no exaggeration. anyway, we got to talking, and now i need a few things: ham radio (not really, but would at least like to get the license), new cb antenna, and to remove the cap. my plan for the cap was to make it into a camper, but since i have the trailer, i don't need it. i'm thinking of a tool box that sits within the frame rails, so if i want to put something like a soft-topper on, i can. just a thought
#759
then you will definitly need to thoroughly test it. that would include but not limit you to a rigorous shakedown...many trips to WOT! I got leathers and extra helmets if you need.
