irab88's 1993 PickUp Build-Up Thread
#721
Originally Posted by 4ever4running
...Wow that looks brand new, nice find!
hey ian,
two quick questions: a) can you explain the no-kickback diode in your 'aux-box' and b) what are your plans for the center console?
i have a 4runner console waiting to be installed between the buckets i put into my truck (also from a 4runner, see my sig) and i wanted to set it up so that my CB set up was hidden inside the console but i'm still working out the details.
b)i plan on hiding a bunch of stuff in the console, namely my cb. however, i have a cobra 75 wx/st. the "box" for it is smaller than a deck of cards, and all the controls are on the mic itself (display, ptt, squeltch, scan, 9/19, etc). that makes mounting it easy, as i only have to find somewhere to mount the mike, not a whole box like most cb's. and as for the switches below: compressor, locker, and lights
mounting idea for the cb:
#722
i do not. but since looking it up, it doesn't look too hard. i don't need to take anything apart or drain anything (unless i do the water/oil pumps, which i'm not). if you want to, i'm willing to come over one weekend and help you out. like i said, shouldn't take too long
thanks. scouring ebay and craigslist paid off. and with free shipping, too!
Gotta love craigslist! I have found a ton of stuff for killer deals.
#728
Are you going to install the front piece that goes around the shifters also. I don't recall if the trucks had just the carpet to the rubber boot or the plastic frame and decorative boot cover.
#733
There are two u shaped brackets you could easily make with some aluminum stock from home depot, just sayin.
That console looks like it is out of a 2nd gen runner
#735
The brackets are more shaped like this l_____l. The front have tabs from the tunnel ram, but I would fab a bracket if you don't have them. I'll see if I can snap a shot later.
#737
thats it ian, the shift trim slides into the console
This screw is what attaches to the tabs on the tunnel ram, so you could just make another bracket for the front and attach it to the tunnel ram, or let it float and see how that works
