irab88's 1993 PickUp Build-Up Thread
Old 04-01-2011, 12:31 PM
  #541
ChefYota4x4's Avatar
HOLY CRAPOLI! lol... I like that you're doing this project and documenting so well. Hey Ian, Rob, would that box be just fine for my 'extra' fuse panel? Just keep it up high and safe for the most part from creek flooding, etc.? lol.
Old 04-01-2011, 12:41 PM
  #542
Lumpy's Avatar
May as well do the intake/battery swap while your at it!!!
Old 04-01-2011, 01:05 PM
  #543
yotarob2005's Avatar
Sure thing, I have mine mounted high under the hood but if you where worried about it you could always mount it in your glove box or someplace you know will stay dry.
Old 04-01-2011, 01:45 PM
  #544
irab88's Avatar
Originally Posted by yotarob2005
I love McMaster Carr, I swear they have everything. I also have that exact same Blue Sea fuse block and I love it too.
i ordered the stuff from mcmaster on wednesday, and it was on my doorstep thursday. sweetness.
also, i like how compact the fuse box is, as it will fit between my battery and p/s reservoir
mount it higher than your battery terminals. that way, you know for sure it's not the weakest link
already done it, unless you're talking to mark, in which case, yeah! get to it! haha jk
Old 04-01-2011, 02:05 PM
  #545
Mine is almost even with the top of the battery, just had to ditch the pesky cruise control box
Old 04-02-2011, 10:56 AM
  #546
Black_1985_SR5's Avatar
where did you get the adapter?
Old 04-02-2011, 11:14 AM
  #547
Rob, ..hmmmm, yours is 86, riight? I'm sitting here, thinking, "Hey, where's his diag. port? ...and wait, CRUISE CONTROL BOX? mines in the kick panel and diaphram on the other side...what's goin on here?" hahaha.
Ian, ..you did an intake/battery swap? Man, my memory is on total overload, man! lol. I can't even picture it...grrr, lol. Yeah, I want to, unless I did a snorkel style intake some day(because I think it would be the ultimate 'cold air', lol. Errr, unless when driving through the High Sierras in July, AZ in Summer, ....yeah, not so 'cool' then, eh? but still cooler than the engine bay! hahaha.
Old 04-02-2011, 12:06 PM
  #548
irab88's Avatar
alternatorparts.com- wasn't an exact fit (see below), but it works better than splicing. it's made for a smaller case, but the plug still fits
yup.
https://www.yotatech.com/forums/f116...e-swap-220884/
also got this shiny new thing! 140 amps of pure electricity!
adapter almost fits
after some light bending, it's secure
also printed up some templates for my buss-bars. only using 2 of them, but wanted to practice
Old 04-02-2011, 12:08 PM
  #549
irab88's Avatar
oh, and dropped off the rover at the gram's 2-car garage. that's where it'll be until i'm done with all the maintenance.
Old 04-03-2011, 05:38 PM
  #550
RBX
RBX's Avatar
nice work, you changing out the fusible link?
Old 04-03-2011, 06:19 PM
  #551
irab88's Avatar
i recently replaced the big "80 amp" fuse(able link) in the stock fuse box, as the old one was corroded. i'll be putting in big in-line fuses for the major components, to avoid serious problems.
today i had started on the buss bars, but the drill press motor gave out. so, i'm going to have to dig out my dad's and do them here. and a hand hack saw works waaaay better than the band saw... huh...
Old 04-05-2011, 09:12 PM
  #552
irab88's Avatar
um, so someone just pointed out to me an alternate meaning to the previous title i gave to the truck. sooo i'm changing it back to the original "red rover"
Old 04-06-2011, 03:48 AM
  #553
RBX
RBX's Avatar
BOOOOOOOOOOOO
I thought the name was intentional, well, i thought it was funny.
Old 04-06-2011, 04:46 AM
  #554
irab88's Avatar
it was intentional, but not for "gutter" reasons.
since i'm a train geek, i thought it worked out perfect. but, alas, perverted minds have once again taken innocent words and made them into a guilty phrase
Old 04-06-2011, 05:33 AM
  #555
RBX
RBX's Avatar
you(well maybe not you) can find perversion in almost every phrase, word, saying.... i wouldn't change it....but its yer rig, and guilty conscience...haha!
Old 04-06-2011, 05:46 AM
  #556
Lumpy's Avatar
To be honest I don't even remember what it said???
Old 04-06-2011, 07:22 AM
  #557
RBX
RBX's Avatar
Ian
what size fusible link did you replace the 80amp with when you did the alternator swap. I am about to do mine, and thought i should match the 120amp found in the MR2 the alternator was designed for. The other posts i have read say nothing about upsizing the fusible link...
Old 04-06-2011, 07:34 AM
  #558
xxxtreme22r's Avatar
Stop me if I am wrong, but I think the consensus is to use a 120 amp fuse to replace the 80amp and upgrade the fusible link wire to the batt to at least 4-6 ga wire and not use a true fusible link. Although some (very few) people have argued that upgrading the slow blow link wire is not safe.
Just posting this as I was thinking of going to a GM alt. and will have to do the same thing. Just wondering if I am right or not. And since Irab88 is the king of wire.......
Old 04-06-2011, 07:35 AM
  #559
irab88's Avatar
do not use a higher amperage fusible link
if it's for the stock fuse box, use what was originally there. the vehicle will only use up to that amount (80 amps in my case). if you exchange it with a higher rating, you run the risk of overloading the stock wires. it doesn't matter what the alternator puts out, as that is determined by how much of a load you put on it. if you put in a second fuse box (like me), you can make that fusible link whatever you need it to be, as long as it's safe
Old 04-06-2011, 09:34 AM
  #560
RBX
RBX's Avatar
I have plans to add another alternate fuse box for accessories hanging off of a deep cycle, so i guess i would put the second fuseible link on that side as well.
I need to look at my wire diagram....
Quick Reply: irab88's 1993 PickUp Build-Up Thread
