Dirt Garage / 1989 Pickup Build!
Old 03-15-2019 | 07:39 AM
COMTB's Avatar
Wow awesome thread and build man.
Old 06-18-2019 | 08:00 AM
Dirt Garage's Avatar
I just realized I forgot about this thread again. And left you guys hanging in the middle of lowering my SAS. Check out the finished video here:
I love the new height, its waaay better for wheeling, and more stable on the road. I would highly recommend lowering your SAS the same route we did.
Old 11-25-2020 | 08:40 AM
I'm back for my yearly update to this thread! Somewhere along the line I installed a e-locker in the front!
I also made a how-to install and wire e-locker video.
Old 11-25-2020 | 08:43 AM
The most exciting mod I have done this year is DUAL T-CASES. I used the Trail Gear R150 to gear drive case adapter, MC 08 Doubler, with 23 2.28 front and rear. The triple sticks are custom made using trail gear twin sticks.
Old 11-25-2020 | 08:45 AM
  #25
To mount it I used the Trail Gear dual case crossmember / skidplate. Super beef! Brand new rear driveline from Pats, and my old square tube was actually to long, and worked perfect for the duals!
Old 11-25-2020 | 08:46 AM
  #26
And yes, of course there is a video on the duals
Old 11-25-2020 | 08:55 AM
  #27
Something else new is these custom built rock sliders!
As you can tell it was a little to late for that rocker.. Haha!
Old 11-28-2020 | 08:59 AM
  #28
swampedout's Avatar
Ive seen some of your videos and never realized you had a build here. A lot of work done on that truck! I think the 3.4 swapped Toys of this generation are the best of everything.
Im curious if you have a review of your Elocker now that youve had it for a while.
Old 11-29-2020 | 03:32 PM
  #29
bone collector's Avatar
You have an awesome thread and YouTube channel. Keep up the great work!
Old 10-20-2022 | 10:30 AM
  #30
Its been a minute.. And alot has happened.
I got tired of putting premium fuel in the Pickup, so I ripped out the supercharged 3.4 in favor of a V8. I landed on a 2UZ originally, it was practically free.
Here I test fit it
before putting it in she got new valve cover gaskets, spark plug gaskets, intake and exhaust gaskets and a fresh paint job.
Spoiler
  #31
Then disaster struck. A leaking fuel injector caused a fire, and the truck burnt up!
Old 10-20-2022 | 10:36 AM
  #32
I stripped everything down, took inside of cab, fire wall and entire engine compartment down to bare metal where the fire damage was. Painted to colour match.
Old 10-20-2022 | 10:38 AM
  #33
There is videos documenting the restoration process for those interested.
Old 10-20-2022 | 10:41 AM
  #34
Now for the new motor! I decided since I bought everything for a 2UZ swap I should keep it in the engine family. So I found a 1UZ, honestly a better option anyways, lighter, period correct, and just looks better in general.
Old 10-20-2022 | 10:50 AM
  #35
While I waited for parts and was in body work mode anyways I decided it was time to bob the bed! Took 11 inches out of the bed.
Old 10-20-2022 | 10:59 AM
  #36
THE V8 IS ALIVE!
Old 10-20-2022 | 11:01 AM
  #37
And the latest major change is finally some chevy 63s!
Old 10-20-2022 | 11:03 AM
  #38
Oh and I ended up going with a Spitronics Stand Alone ECU and harness
Old 10-20-2022 | 11:59 AM
  #39
rattlewagon's Avatar
Watch your stuff on youtube all the time. Keep up the sweet work!
Old 11-11-2022 | 09:31 PM
  #40
Sundown's Avatar
No 4th gear???
Originally Posted by Dirt Garage
Next up was manual swap! The original plan was to keep the truck auto with 3.4 swap, and even bought and installed the Inchworm adapter and 4 cyl t-case. Problem was the wiring, for some reason that trans did not work in reverse, and just overall was not happy! Me, now being confident in my mechanical skills after successfully engine swapping, decided to give the manual swap a go.
The 3.4 auto trans next to my new fancy manual transmission!
Hello! Im having a swap done right now and ran into one issue that you seem to not have...so hoping you can help.
Vehicle is an 89 pickup auto 4x4 with 3.0
Donor was 2002 tundra 3.4 2x2 auto
ORS says that you want to use a T100 ECU to avoid issue, so that is what we did.
The mechanic did all the wiring, no ORS harness at all.
Everything is connected and working except 2 things...below is the message from the mechanic.
"Your model year happens to be a hydraulic controlled t-case, so those two last wires (S4 & ECT PWR) directly connects into the ECU..
S4 & PWR for ect is not present on t-100’s ECU so i’m stumped!"
So it drives and shifts fine, but wont go into 4th gear/ OD. AND...I guess the ECT things doesn't work...dont really care about that,
Any advice...how to get an auto transmission to shift into 4th gear?
