dark_fairytales 1986 Pickup Build-Up Thread
#161
Does the extended lines look the same as the stockers and connect the same? A 2 stocker together is great idea cost and easy to get new one for a DD and mild trail goer, you could still carry a spare stocker, it is a great idea :}
#164
My current hold up on things; has been caused by going to school, and now I am in the process of trying to buy my recently passed on, grandmothers house. Once I get everything squared away with the purchase of the home, I will be able to get my yota off the back burner again.
I have been itching to work on the truck some more, and I am having withdrawals because I can't.
#165
Sorry I have been so absent for that past four months. I am starting to slowly return to see what is new around here. I have been anxious to get some more work done, and head out on to the UN-beaten-path.
So here are the updates. By May 30,2012; I will be a home owner. That's right, I will have a garage for the future mods to come. I am extremely excited to be able to buy my Grandmother house, as it has always been a second home too me.
Also, for any of you locals who need some welding done; come on over. I have the welder, and the proper space to do it.
See all of you around soon.
#173
At some point a want to have a pool party at my new place, and invite all the locals over, for a potluck BB-Q
#174
just went thru your thread. good work on everything. due to one of my upper control arm bushings falling out. i maybe going BL LT sooner than later. heard you said the shocks maybe to stiff. i dont see any other options?? anyways more info and pictures of the LT in action if possible. thanks
#176
I will be getting these for the rear. http://www.summitracing.com/parts/BSN-24-185752/
#178
On another note, I smelled some hot coolant while driving to the house to do some work. I pulled over into a parking lot to discover one of the freeze plugs popped out, and ejected all of the coolant all over the drivers side front wheel. I made a call to my bother to come pick me up, so I could get a new freeze plug. After getting the freeze plug, and some water, it took me about 20min. to get it running again. Obviously I did not get any work done at the house today before I had to go to work.
