ChefYota4x4's 1987 4Runner Build-Up Thread
Old 07-18-2013, 03:30 PM
  #7161
ChefYota4x4's Avatar
Better look at the powdercoated dial and ring I swapped in..... (all the insides are SFA Hub innards)....
Here is the switch from Pepboys.... But I'm going to look into the link that Ian gave me.... Just a picture...
And this is the picture that I cropped which I was trying to use for my ID picture... but it won't let me...
Old 07-18-2013, 03:35 PM
  #7162
Sorry Red.......
4 inch Trail Gear lift springs front and rear... but with six inch shackles in the rear. it will most definitely settle some... but it will still be close to that last picture..
  #7163
Cyberhorn The Dragon's Avatar
mark too much pain will actually make it take longer to heal its why their (the drs an hospitals) so much into pain management if your hurting take something
me im a tough old hard scaled dragon that has been carved on since i was 4 (4 corrective eye surgeries from 4-9 yrs old) ive likely had more time under the knife than you rich an terry combined
if your hurting take something go sit down an stay cool that will help the antibiotics work an not stress your system which slows your immune system and the meds giving the infection time to get dug in an take longer
Old 07-18-2013, 04:28 PM
  #7164
Thanx, Will....
I already have and shall remain here til tomorrow, aside from getting up to move a couple times ( my fairly screwed up back will not allow me to sit here for the next several hours and then lay down in bed for the next 8 thereafter... I would be an absolute agony in yet another way! lol. )
I'm sure you have, and I do not envy you in that realm, dragon my friend! I've been quite the mess at times in life though... nothing like what you're dealing with right now which is just traumatic. You've been through so much but I guess you're better able to handle this chapter... but wow! I'm just pretty much broken almost every bone in my body including my skull and a couple vertebrae and herniated discs... just lately it's become a lot more tarsal bones issues and heel and joint and tendon as well... I guess you could say I just totally overdid it with sports and extreme recreational activities and so forth to the point where I'm paying for it now, probably much earlier than I should be. And one thing is for sure, and that is that I've known my share of fairly radical painful incidents... I suppose the two accidents near death experiences didn't help the situation either. hahaha... but I'm still here!
What's really interesting, regarding the current foot pain, is that I remember, as a child of around 12 years old, I would suffer from what is called Osteochondritis... it's actually the opposite of Caesars disease, which causes way too much blood in the Achilles tendon... mine was actually the opposite where it was a lack of blood that would cause just sudden and Incredibly stabbing pain... sometimes causing me to just collapse because my ankle would.simply give out... I can even recall one time being in an obstacle course when that occurred, and while I did finish, I was on the ground for about 10 minutes and could not put any weight on my foot at all. Then, it would just go away, and eventually , I can't recall exactly when, it just went away completely . The other thing I remember is having migraines so bad but I would literally get physically ill/throw up. This went on for years, and they could never find an answer as to why but did suspect that it was the fact that my right eye had such weaker vision than my left... Eventually that seemed to stop as well. Over the last couple years, I gotta say, I have spent way more time in pain than I am comfortable with! lol.
Okay, well I guess I will just do a little reading this evening and make a decision one way or the other on most everything that I have left to get. I got a trucker helping me decide on a radio... several Electronix gurus are helping me decide which switches and so forth... a couple of 4 wheel drive gurus helping me decide on a winch. .... And the rest of you, no less important, ever, in helping me make up my mind on things. I guess I just sometimes have a hard time deciding because I want to make the right decisions the first time on things that will last me a long time. even the rear bumper was a decision that I felt would be so beneficial in the end because I could tow with it and it would take one hell of an impact, compared to some of the other ones.
I know the bumper isn't the most popular spot to mount a CB antenna... but considering mine mounts to the frame securely and is quite a mass of metal in and of itself... I thought putting a tube mount and may be running a 5 foot tunable Firestik or Wilson... what do you guys think? I have a hole in my roof behind the moonroof already. that's where the previous owner had a CB antenna. he took it with him when he sold the truck and left the Mount with the larger style spring base up there.... I could easily run the coaxial but was already there back up to that spot... but I'm pretty sure I would have to bend that thing back quite a bit or just remove it altogether when I'm not on the road. I'm not positive that my roof rack will clear it either... I will have to look at some pictures.
Old 07-18-2013, 04:53 PM
  #7165
you could use the roof rack as the base spring it so wind doesnt try to rip things off with a bit of give but also as the rack is over fiberglass get whats called a ground plane enhancer they used to have them a hex sided ball that threaded in under the antenna it had 3 -5 short 7 inch sub antennas to help make the CB transmit a flat long signal not high domed my whips both had them an i got excellent performance
http://www.ebay.com/itm/TRI-STAR-Cb-...-/300926758097
(also would pull the antenna off with the rack when not needed in normal traffic)
Old 07-18-2013, 04:59 PM
  #7166
Does that mount flush to the roof too? Likely in that spot where the PO had the antenna?
Old 07-18-2013, 05:03 PM
  #7167
http://www.walcottcb.com/cb-antennas...7_352_425.html
Old 07-18-2013, 05:05 PM
  #7168
it can if the threaded part is still there sure could!
one thing i caution you take your rig when you have the parts together cb antenna ect to a cb shop so it can be tuned or you risk cooking the radio they have to set the SWR's of the radio antenna truck assembly with a gauge they have in the shop you can listen to it but dont transmit till ya get the setting you'll notice too with it tuned you hear further an send farther as well with far less static
with whips they some need minor trimming or adjusting of the metal core (mine had these) i actually melted a set of fiberglass whips that were tuned wrong LOL
snuck in with that link the wilsons are a good brand and tune well 1/4 turn an off they come for garages an low ceilings
Old 07-18-2013, 05:13 PM
  #7169
What is in the link.? I was thinking a well grounded/tunable firestick or otherwise
Old 07-18-2013, 05:18 PM
  #7170
that would thread into a antenna base so like
coax wire--antenna base -- ground plane -- antenna (firestick whip type)
i wish i had a picture of my old 88 nissan kingcab with its dual whips right behind the cab with the ground planes when i worked security it came in handy talking to truckers an parts trucks coming in to unload
Old 07-18-2013, 05:54 PM
  #7171
Double post, sorry
Old 07-18-2013, 05:57 PM
  #7172
And these units so far...
Larger, under stereo mounting.....
OUCH!!!!!!!!! LOL........>>>
Yaesu FT-7900R Mobile Dual-Band Amateur Ham Radio 50W/45W VHF/UHF Transceiver
Amazon.com : Yaesu FT-7900R Mobile Dual-Band Amateur Ham Radio 50W/45W VHF/UHF Transceiver : Electronics Amazon.com : Yaesu FT-7900R Mobile Dual-Band Amateur Ham Radio 50W/45W VHF/UHF Transceiver : Electronics
More reasonable......
Amazon.com: Uniden BEARCAT CB Radio With Sideband And WeatherBand (980SSB): Car Electronics Amazon.com: Uniden BEARCAT CB Radio With Sideband And WeatherBand (980SSB): Car Electronics
Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather Stations and Selectable 4 Color Display
Amazon.com: Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather Stations and Selectable 4 Color Display: Car Electronics Amazon.com: Cobra 29 LX 40-Channel CB Radio with Instant Access 10 NOAA Weather Stations and Selectable 4 Color Display: Car Electronics
Uniden PRO520XL 40-Channel CB Radio
Amazon.com: Uniden PRO520XL 40-Channel CB Radio: Car Electronics Amazon.com: Uniden PRO520XL 40-Channel CB Radio: Car Electronics
For glove or console....
http://www.amazon.com/gp/aw/d/B00004...an_am_ap_am_us
( there are literally hundreds of these many units that can fit in the console or glove box... or under the dash or up above, all without too much effort. I have A 2 compartment console... its pretty deep and I'm fairly positive I could mount 1 inside... or maybe even on the back...)
Or this route for handheld/more portability/ easily take it with you inside anytime .....
Cobra 75WXST 40-Channel CB Radio
Amazon.com: Cobra 75WXST 40-Channel CB Radio: Car Electronics Amazon.com: Cobra 75WXST 40-Channel CB Radio: Car Electronics
http://www.amazon.com/gp/aw/d/B00000...an_am_ap_am_us
More gear....choices....
http://www.amazon.com/gp/aw/d/B000X3...sr=1-3-catcorr
Redman CB Wilson Firestik Francis Astatic Cb Radio Antenna Ground plane 3/8 x 24 Black Tip Mirror Trucker
Amazon.com: Redman CB Wilson Firestik Francis Astatic Cb Radio Antenna Ground plane 3/8 x 24 Black Tip Mirror Trucker: Everything Else Amazon.com: Redman CB Wilson Firestik Francis Astatic Cb Radio Antenna Ground plane 3/8 x 24 Black Tip Mirror Trucker: Everything Else
http://www.amazon.com/gp/aw/d/B00042...sr=1-1-catcorr
http://www.amazon.com/gp/aw/d/B000SB...omotive&sr=1-4
Mirror-Mount Kit with CB Antenna Coaxial Cable - BROWNING
Amazon.com: Mirror-Mount Kit with CB Antenna Coaxial Cable - BROWNING: Everything Else Amazon.com: Mirror-Mount Kit with CB Antenna Coaxial Cable - BROWNING: Everything Else
Meter for reference / those interested.....
SWR METER for CB Radio Antennas with 3' Jumper cable - Workman SWR2T & CX-3-PL-PL
Amazon.com: SWR METER for CB Radio Antennas with 3' Jumper cable - Workman SWR2T & CX-3-PL-PL: Car Electronics Amazon.com: SWR METER for CB Radio Antennas with 3' Jumper cable - Workman SWR2T & CX-3-PL-PL: Car Electronics
From what I've been told by several people in the know, as far as for working on a trail and even up to a few miles ahead, the handheld mini units without a box are probably the best way to go because I can simply unscrew it and take it with me inside whenever I'm not on the road trip. In that case so far I've found those Midland or Cobra, whom also makes Uniden..... I was told pretty clearly the ground, not coiling the coax and proper tuning can make most any of these radios work well... granting that they are not one of the more problem units nowadays.
Low range off road , 4 crawler, Wolcott and others have a great write-up to answer many of the questions.... I pretty much know what I want to do but the only part that I'm not sure about is how and where to mount my antenna. I posted a few above,....
What do you think?
Old 07-18-2013, 06:37 PM
  #7173
kornhuskerwizard's Avatar
looks nice!!!
Old 07-18-2013, 07:14 PM
  #7174
bone collector's Avatar
looking good chef! keep up the great work!!!
Old 07-18-2013, 07:53 PM
  #7175
ya dont need a SWR all the time unless your talking sideband which is like talking on ch 21.1-21.9 which makes people who arent wonder what the bleep are they saying as it garbles ya but it makes your talk clear as a bell they set your SWR on the middle of the radios range of channels so you get good reception transmission from 1 - 40 sideband talking blows that out to .01- 40.9999 unless your really into CB dont worry bout it (i had to have a frequency counter so when i keyed up i could see where the heck i was LOL)
this radio has it built in too cool! ch 40 is also 27.405 Htz
yes i am a child of a trucker raised part time in a rig so got infected with CB when very young LOL
i wonder do they still have the cb units where the microphone handheld has the channel display on it the main unit is under a seat hidden remove the mic an its safe cant use it without the mic which is compact an unobtrusive
ahh you did find them the
""Or this route for handheld/more portability/ easily take it with you inside anytime .....
"><img src=" /> ">
"" those would keep themselves out of the way and easy to keep picked up no ones knee in the shiny corner when rollin over a rock
as for the links
unidens not bad back when i used CB's but had vibration shaking issues components came loose
cobras were always good
dont know the yaesu
the firestick looks good thats the kind i had with my old truck they dont get hot and the cb shop can quickly get the SWR's set with the adjustable tip
the mirror mount would work well for your rack unscrew the coax unplug the lights off comes the rack after a wheeling trip
the coax cable you want it to be heavy gauge as you can an short as possible to the antenna for best results
Old 07-18-2013, 08:26 PM
  #7176
Red Wagon's Avatar
OOhh, getting a CB or UHF? Just saw that my dad has a license. I think he can test me for the license? Not sure.
Such an old hobby, don't know many people who do it. My dads old though so....
Old 07-18-2013, 09:05 PM
  #7177
Ocell's Avatar
I just ordered all the parts (I hope) to get a CB running.
I'm not going for maximum range, I'm just looking to talk to other wheelers within the parks I go to, so I'm not worrying too much about the rules of mounting the antenna.
I'm planning to do this mount setup:
I got this antenna because it is supposed to be flexible for hitting stuff offroad, but it's not a super long wire wip that could hit spotters:
Amazon.com: K40 SF-300 Black 3' 1000W Superflex Tunable Fiberglass CB Whip Antenna: Automotive Amazon.com: K40 SF-300 Black 3' 1000W Superflex Tunable Fiberglass CB Whip Antenna: Automotive
And I got this mount:
Amazon.com : Firestik SS274 Adjustable Stainless Steel Hood - Trunk Channel Antenna Mount : Firestik Side Mount : Electronics Amazon.com : Firestik SS274 Adjustable Stainless Steel Hood - Trunk Channel Antenna Mount : Firestik Side Mount : Electronics
I'll have to mock it up on the truck first, but I may hammer a 90 degree bend in to that mount to get it to wrap around the corner over the tail light as it is in the photo of that white 4Runner.
Old 07-18-2013, 09:49 PM
  #7178
well any whip on a spring can hit people who shouldnt be that freaking close while things are in motion...
tennis ball to keep it from whacking the fiberglass top would be a good idea
Old 07-18-2013, 11:23 PM
  #7179
Cool post, C! Thanx for sharing/for the links.... Is that going into and then mounted on the Tailgate jam?
Gotta put a hat on the whip! Haha
Old 07-18-2013, 11:30 PM
  #7180
Lil video of the light bar in the dark.....
Quick Reply: ChefYota4x4's 1987 4Runner Build-Up Thread
