94 Pickup 3VZ-E 4x4 XtraCab build
Old 08-30-2016, 01:53 PM
iourius's Avatar
Hey sorry it's been a while but I've been working away here and there as life allows but I also lost lots of pictures as my phone died and I lost everything until that point..
Old 08-30-2016, 01:56 PM
iourius's Avatar
Old 08-30-2016, 02:05 PM
iourius's Avatar
Weeks of work, grinding everything down, replacing damaged parts, had to create a custom tool to separate the bearing case as they were both damaged and bearings were worn.. Cleaned everything the best I could and repainted with rust inhibitor, then rust paint and under coating on the frame..
Old 08-30-2016, 02:10 PM
iourius's Avatar
Sand blasted and rapainted..
Heavy duty leafs!!
New shocks as well!
New rubber on the freshly painted rims!
Looks way better!!
Old 08-30-2016, 02:15 PM
  #25
iourius's Avatar
New fender with fresh paint.. New potebtial colour!
Pretty close to ready!
so got it running with new parts and fresh fluids in everything.. A rad hose blew and since it was attached to the thermostat I ended up replacing that as well... Test run is complete and everything is working perfectly at the moment.. Just a few minor things to complete.. Working on the bumper to remove all the rust and repaint it..
Old 08-30-2016, 09:17 PM
  #26
SCLead's Avatar
Wow, looking good man! Love how clean you're getting the rusty old crud to look!
Old 09-01-2016, 08:01 AM
  #27
iourius's Avatar
Thanks man! Took lots of hard long days to remove all the rust.. several days I didn't want to go back under there for hours to grind but it had to be done and I couldn't be happier with how it turned out!
Had to replace lots of rusted out parts which I didn't plan to until I started to remove things and I didn't want to put any old rusty parts back on just part of doing a job right and hopefully only having to do it once!
Old 09-23-2016, 11:54 AM
  #28
iourius's Avatar
Got lots accomplished but working on body repair.. Patched the big hole and still need to go over the other parts to maoe it perfect but all in due time.. Got it insured and driving now so pretty damn happy with it.. Only minor things left except Code 71 came up which I'm trying to solve right now..
Interior is good and clean just need to put the boot back on for completion. Then looking for speakers to put in the rear..
Multicolour joy haha
lfcarrion3
04-05-2016 09:09 AM
jeepfreak4648
02-26-2016 07:16 AM
jeepfreak4648
02-26-2016 05:39 AM
alva22re
02-20-2016 04:21 PM
Quick Reply: 94 Pickup 3VZ-E 4x4 XtraCab build
