8T8 4RUNNER's 1988 4Runner Build-Up Thread
#1421
OK.....bought the stuff at the Auto-Zone up by Brandon's.......that's right.....I drove past with Joe......I was gonna pose a pic w/ your truck but I figured either you would spot me or your neighbor would hit on me.....hehehhehe
#1423
so one of those nagging, not-so-fun, PITA projects was Joe's hood. whatever paint was used on the inside of it was crap and peeling and some attention was going to be needed before it went back on.
sooooo....commence with the wire wheel and vacuum and compreesed air sprayer , repeat, repeat, repeat..
and you get this
add in some Joe and some Bar-B-Q grill paint.......
and you get this
and leads to a nice simple happy moment of being able to close the hood
and you get this
and you get this
#1429
tanx...
still quite a bit to do:
alternator
emergency brake cable
exhaust leaks
fender
inspection
enjoy
OK...that's not a BAD list after all.
alternator
exhaust leaks
fender
inspection
enjoy
#1431
sooooooo......
the ONE can of that alternator cleaner I bought, lasted about 1 minute and I got about 1/1th done.....boooooooo.
gonna have to pick up a few more cans tomorrow......boooooooo again.
cleans very nicely...stinks...but does the job.
#1436
#1437
soooooo.....some pics.
not so sure what I am accomplishing, if anything, spraying that stuff in there.....seems like I'm just gonna be moving crud around and it's going to accumulate somewhere else.
but anyhoo...
here is the stud that I think may be some, if not ALL of the problem. the nut that holds the wire on is damaged......my assumption is that something bad happened once causing an arc.
probably not the best pic.....but.....I'm going to work on these threads a bit more.....???sandpaper???....what else??
and .....ummm....it does this to the driveway
here's the nut...does not look good. mid you, this is the way it was when I was putting it back on.
but anyhoo...
#1440
