8T8 4RUNNER's 1988 4Runner Build-Up Thread
#1323
nah....181 oughta be nuthin'......1 hand is right "OLD MAN STRENGTH"....hehehehehe
killed that other bolt on the catalytic converter.....Thorley adapter mocked in place for sizing.
#1324
and PROOF.....it's only mocked-up to make sure it fits. it IS upside-down.
debating whether or not to use a donut gasket as well as the flat one provided. we could debate about that tomorrow.
#1325
Brandon.....let me know what you want to do. I would certainly appreciate if you could come down.
qualified and experienced eyeballs are definitely wanted.
#1328
Staff
181 lbs takes alot of grunting to get it tight. Great job on that. Dont know why they have to be so tight. I had a 5 foot cheater pipe and still didnt have enough butt to break on loose. Sometimes just getting it on and off is an accomplishment.
#1329
Brandon....bring your timing light......
whatever time you want to come is fine. wife is off. I announced yesterday that THIS is what we were doing today.
cant get the alternator "just tight enough" feels like too much play in the belt. nothing really to wedge against, so I'm open to suggestions.
really up in the air about using a donut gasket on that catalytic connector.
near as I can remember, we have 3 pipes left to hook-up for the exhaust. each one may need a cut....nervous about that. really want your opinion on that. i do have an exhaust pipe cutting tool from a friend. we also have scrap that i can practice on.
want to get that exhaust all put together so we could lower the truck down. not cool with it so high in the air right now and my step i use, is being used as a wheel chock.
LIST:
have to put the throttle body back on the intake plenum,
need to torque about 3 bolts on the driver's side of the tranny.
driver's side spark plugs
torque crankshaft bolt
heater core hoses......and check all connections
injectors and fuel rail
remove 2 bolts from each valve cover and place on the supports for the wire harness
wrap wire harness with new tubing
intake plenum
vacuum hoses
throttle cable
spark plug wires
fan
radiator
add oil and water
charge battery
start it up
LIST:
intake plenum
vacuum hoses
throttle cable
spark plug wires
fan
radiator
add oil and water
charge battery
start it up
#1330
sooooooo....
a nut won't fit where it's supposed to on the O2 sensor bung. going to have to grind a nut down to see if we could get it to fit. not good.
#1332
transmission torqued.
down 2 more fingers.....only 7 left. (yes, that other finger injury is still no good.....tendon sheath for sure)
#1340
Holy Crap, that's quite a list... hope Brandon got that! lol. Quite the good dude, is B!
Hey, .... by the way, .... KILL IT! lol. And seriously though.... JERRY, I sense you're a bit OCD like myself and, well, YOU'D RATHER HURT YOURSELF than give up! LOL. PLEASE, be careful with your hands, .... I actually got up today and both were really numb. Whenever I push it like I have been lately, that happens, ...and then, I wake up almost emotional, thinking, "HOLY CRAP, these things are my LIFE!" .... And then I think of the Surgery that my buddy had for Carpel Tunnel...... and he's STILL having issues. I'm nervous, and you'z a HEALIN MAN, ...so just be careful, K?
CONGRATZ, JERRY, JOE! Did I say, ....KILL IT? yes, do that, and then 'VROOM VROOM VROOM AND'A BOOM BOOM' next week, some time??????? Heck, MAYBE TOMORROW????
