1UZFE into my 95 runner
#384
Dang! That is a killer price!! If I only had the money for that lmao. I would jump all over a deal like that.
#386
Well I have hit wall. Took my runner to have the emissions checked. Well she runs a hole lot cleaner then the 3vz. My problem is that it failed because the engine dose not have air injection. And I have to have it inspected and because it is obd2 it has to pass all of the monitors. My engine will not run all the monitors as the thing thinks its moving. Bummer. Looks like I get to get the ecu from adaptronics sooner then later.
#389
93-94 LS400 uses similar ECU with OBDI. I've swapped ECU's in my Cressida to confirm. Also, OBD1 ecu doesn't care about A/T codes and speed sensors. My LS400 CA ecu is throwing transmission codes because I'm using a 5spd. Swap the ECU's and double check all pinouts are the same for the emissions crap and go back for testing.
I've been following your thread for a while thinking about doing a 2uz swap in my 2nd gen. Good luck!
#390
024runnerse the 2uz's are nice but heavy. An I wanna go with the aftermarket ecu anyways. I have decided I wanna put q supercharger on it like yota3.0 did. Because in going to do armor and a exo-cage so I'm gonna be turning her into a fat little piggy an I still want the power to take off like a bat out of hell. I can already feel the drag on it when I have the 295's on.
#394
Well went to wheeler lake again today. Well two real broken coils an a broken rear right shock and I'm not gonna be able to go to the jamboree. Lame. I'll put up some pictures in a bit.
#398
HOLY CRAPOLI! that sux! Sorry to hear, man... glad it's not a "My 1UZ Explodeded!" post though... Hopefully you'll have it done pretty quick... sorry you're missing the Jambo, Shaggy/Zach.... was looking forward to some pics and video of that.(I know, I know.. not as much as you were looking forward to shooting them, no doubt).
