1UZFE into my 95 runner
Old 01-22-2012 | 12:10 PM
  #341
SHAGGY21's Avatar
no. no locker in her yet. i have one i just need the money to rebuild that too. im not making $h!t for hours at work. only made 51 hours on the last check. i finally scrounged up the money to get my water pump and oil pressure bypass valve. she is leaking coolant and the oil pressure drops off when at idle at operating temperature. with im sure is a pre-existing problem from looking at the original head that i pulled off of it that had the cam journal. cams are the end of the line on oil pressure. i just really dont want to pull the pan off.
Old 01-22-2012 | 12:14 PM
  #342
RBX's Avatar
RBX
The saggy rear probably isn't helping either. The meats look good.
Old 01-22-2012 | 12:32 PM
  #343
ChefYota4x4's Avatar
Oh wow, that sux! I hope it ends up being the least amount of drama possible, Shag!
  #344
SHAGGY21's Avatar
yeah. hahahaha i had to reread that a few times before i realized it said saggy and not shaggy rear. i was a bit confused there. im not gonna lift it anymore i have decided i may fix the saggy a$$ or just drop the front end as it sits a little higher then i would anyways with the lighter engine. will see where the money is at. and thanks RBX an chef i do what i can.
Old 01-22-2012 | 01:03 PM
  #345
RMA's Avatar
RMA
man i need a manual 1uz .. Hahah ! great job bro .. how about a burn out video on the street ... but dont get a ticket
Old 01-22-2012 | 01:09 PM
  #346
SHAGGY21's Avatar
yeah no ticket hahaha my friend almost got a ticket just pu the street for doind a burn out in reverse in his volvo in the snow with a cop behind him. hahahaha.
what manual u need ill have a look an see if i have it.
Old 01-22-2012 | 04:29 PM
  #347
I think he means 'I wants me 5 speeds and a clutch!' lol.........eh chem.......... or maybe not? hahah.
Old 01-22-2012 | 04:34 PM
  #348
SHAGGY21's Avatar
Hahahahahaha o.
Old 02-05-2012 | 12:37 PM
  #349
SHAGGY21's Avatar
well i did my water pump the other week. was leaking from the weap hole. i used a a tundra pump so i didnt have to glue the pump on. the tundra pump comes with a metal gasket with an oring in it. got it from workl pac. and here is the number for it. also glued the heater pipe in with the o-ring just dont trust o-rings all the time.
also put the oil pump bypass valve in on friday as with the snow there was no work what so ever. pulled the pan and found this. im gonna have to find another engine. also pulled a rod cap to check the bearings. not so bad but not the best. so when i put oil back in it i used 20w50 and when the engine is hot at idle it only has 14.5psi for oil pressure and spec is 47psi
also ordered the parts for my locker will be here on tuesday. yes i cant wait. as i got stuck in my alley trying to pull my subaru out by my self. we got like foot and a half of hevy wet snow. and i am gonna build a new rear bumper with a tire hanger. or i may try and put a 90 stock rear hanger on it. will see when the time comes.
Old 02-05-2012 | 12:47 PM
  #350
RBX's Avatar
RBX
That stinks about the engine, and getting stuck. Heard you all got a good dumping of the white stuff.
Old 02-05-2012 | 12:50 PM
  #351
SHAGGY21's Avatar
yeah we did. and i slid off the road for the first time ever only because two cops were parked on the blind corner of a onramp. dip wads. about the engine i think it will last a little bit though ill just keep good oil in it with moa. she is a trooper.
Old 02-18-2012 | 03:08 PM
  #352
SHAGGY21's Avatar
ok so i got a little bit done today. put a set of manual locking hubs on. and the good news is they fit behind the center caps.
also got a new tailgate with a tire rack. will put this in next week.
also got a chunk of frame to fix my rear bump stop.
i also now have all my locker parts. just need to build the harness. then i can throw it in.
Old 02-20-2012 | 07:23 AM
  #353
brotherdrummer's Avatar
retaining my automatic pistol grip shifters
Hey everyone,
Sorry in advance for stepping on any toes here, first time post, so yea I'm a newbie but I have been lurking doing research for some time now.
Anyway awesome forum and I have been able to answer most of my questions by looking around, but does anyone know if I use a older (91') transfer case (not hydraulic) passenger drop with the 1995 lexus SC400 auto will I be able to keep both of my pistol grip shifters with out modifing my center console?
I currently have a 1uz ready to swap but just trying to keep my interior stock as possible. Thanks
Old 02-20-2012 | 08:25 AM
  #354
SHAGGY21's Avatar
Thanks man.
As for your question as I didn't do the auto in mine I may not be the beat to answer this. I know RMA would most likely know it. But from what I know I am pretty sure that almost all the A340 transmission cases are somewhat the same. Such as A340f A340H and so on. Like when you see a 96 and up taco or runner with sas there is a adapter to but a pre 90's passengers drop gear case in. But like I said I may not be the one to answer this question.
Good luck on the swap man its so much fun to drive.
Old 02-20-2012 | 11:06 AM
  #355
Thanks shaggy, I am super stoked for you, great build too.
Don't know If RMA is still dropping by but..........
I have 1995 passenger drop hydraulic t-case, with a (automatic looking) pistol grip lever in the cab to operate the t-case. I like shifting on the fly (ADD) does this mean I have to keep the hydraulic or can I use a manual shifting type of T-case (93-94 t-100 t-case) and still have ADD? And if I go with this
T-case can I still use my pistol grip type of shifter?
thanks
Old 02-20-2012 | 01:11 PM
  #356
SHAGGY21's Avatar
As far as the automatic goes I'm not sure if you can put the hydro case on a tranny that dose not have the ports to feed the t-case. But as for the ADD as long as you wire up the switches to turn the vsv's off an on when you put in 4wd. As it base no part of the t-case other then a signal telling the 4wd vsv to switch.
Old 02-23-2012 | 08:14 PM
  #357
SHAGGY21's Avatar
got some more done today. i put my new tailgate with tire carrier on. i also found some big rust holes in the rear quarters. not to suprising but still. i only have a picture on the hole and not the repaif i did as im somewhat ashamed of it. haha. but what can i say i just put a 100 doller set of speakers in the back that were retting wet. had to do something. also got my new uz badge.
just drilled the holes and used some body washers with the factory bolts. i was hanging off the thing and bouncing and it didnt so much as move an inch.
on more thing off the never ending list. hahaha.
Old 03-24-2012 | 07:16 PM
  #358
xTRDKenny92's Avatar
Very nice build! Where did you find the 1uz badge at? Im working on my swap right now, and its getting pretty intense i can't wait to hear it fire up after seeing your videos
Old 03-25-2012 | 10:40 AM
  #359
SHAGGY21's Avatar
Thanks man. You live in Denver right?. If you want to ever have a look at it for a better insight or something. Because pictures don't ever capture everything. You can man. But the badge 85toyman pointed me to it. Got it off eBay. Just search 1UZ I think it was the second page.
Old 03-25-2012 | 11:34 AM
  #360
I found it, thanks. I live in portland, oregon. I should have mine done here in a few weeks. Need to run exhaust, install cooling system, and finish up the motor mounts. And yeah i know, they really don't, it would be great to see it in person!
Quick Reply: 1UZFE into my 95 runner
