1986yota4x4's 1986 Pickup Build-Up Thread
#201
gpt sp,e questions for you guys, i need a new radiator, how does this one look? http://www.ebay.com/itm/400247621581...fvi%3D1&_rdc=1
also when im driving, ill go to down shift from second to first and it does not want to go into first, i have to really push to make it go, any ideas on why its doin this?
#205
Does it jump out of gear at all?
#207
IM not going very fast at all, no it doesn't jump out of gear. Sometimes it only wants to go halfway into reverse, then I let the clutch out a little bit it goes right into reverse
#210
Great vids!
I've driven one with 25K on it a few years ago.... same thing, 1st is a really low one on these. Reverse, as mentioned, also was a lil sticky, just like mine. For reverse, i just put it in first, then it drops right over and into reverse.
For 1st, I have never downshifted into 1st unless I am barely rolling... it's just not practical with these. However, if I slap it into 3rd, then clutch and slowlyyyyyy slide it into 1st, it WILL go a lil easier. IMHO, 2nd is plenty low to get to a stop.
Nice work, bud! Looks great, too!
#213
I know when a change the cutch in my chevy, I had the fly wheel cut. it's like when you cut your front disc brakes. all the marks are gone nice smooth surface.
#215
Staff
Congratulations on getting your motor running. I know it gave you some problems, but you got it beat. I know that has to be a relief for you. Bet you get an A+ in class now. Great job.
Like Chef said sometimes you have to throw it into a different gear. The shifter bushing isnt bad to replace and more then likely it needs it anyways. Other then that I am not much help on your tranny issue.
