bindergirl's 1981 Pickup Build-Up Thread "The Perkulator"
Old 03-09-2010, 09:05 PM
  #101
bindergirl's Avatar
Once the c-clip is removed yo can pull the indicator... make sure the dial is in the free position, on the backside you can see a notch where the ball bearing will pop out (red arrows) Be careful they can launch themselves...
Green arrow indicates the o-ring which you should be replacing if you are going to do a rebuild.
Old 03-09-2010, 09:07 PM
  #102
bindergirl's Avatar
Ball bearing removed & pulling the spring
also very small ans easy to lose.
Old 03-09-2010, 09:13 PM
  #103
bindergirl's Avatar
that is it for the break down on the hub face
Now removing the hub body...
Remove the nuts, lock washers, & cone washers. Gently tapping the hub body with a dead blow knocked all the cone washers loose.
Old 03-09-2010, 09:15 PM
  #104
bindergirl's Avatar
once all the hardware is off you also need to remove a snap ring then the whole assembly will slide off.
Old 03-09-2010, 09:18 PM
  #105
bindergirl's Avatar
Here is a picture of the clutch assembly and roughly how it goes together... it had come apart and I had to remove it in pieces from inside the hub body.
Old 03-09-2010, 09:19 PM
  #106
bindergirl's Avatar
picture of all the parts as I have been removing them
Old 03-09-2010, 09:22 PM
  #107
bindergirl's Avatar
That was as far as I got lastnight... today at work I threw the faces in the steam cleaner
Old 03-09-2010, 09:24 PM
  #108
bindergirl's Avatar
Taped everything up with electrical tape
and hit 'em with the media blaster
Old 03-09-2010, 09:25 PM
  #109
bindergirl's Avatar
Old 03-09-2010, 09:27 PM
  #110
bindergirl's Avatar
I painted them when I got home, and there they will sit untill tomorrow to cure.
allright thats it for tonight... hub body tear down and paint tomorrow.
Old 03-10-2010, 02:14 AM
  #111
92 TOY's Avatar
bindergirl,
excellent write-up and work.
Old 03-10-2010, 10:27 AM
  #112
aviator's Avatar
^x2... nice to have access to steam cleaners and media blasters...
also shows what can happen when you skip using the proper gaskets and try to make your own...
did you put the parts in the oven for a while after painting to bake or just air dry?...
one previous rebuilder mentioned that he added a coat (or 2?) of clearcoat for additional protection after he polished the raised arrows/letters to remove the paint from those surfaces...
Old 03-20-2010, 08:15 PM
  #113
ancich's Avatar
Exclamation
nice truck, haha i saw it on craigslist back a lil bit ago, they wanted 1750, i showed it to my dad and all he said was, old man special
Old 03-22-2010, 12:31 PM
  #114
Al's Chop Shop's Avatar
nice build up so far, looks a lot like my 81!
Al
Old 03-23-2010, 12:42 PM
  #115
HuKiT's Avatar
Nice Build! Keep up with the pic's it will come in handy when I do mine
Old 05-03-2010, 02:49 PM
  #116
toyospearo's Avatar
things are looking great on your truck!
I spent the day cutting out a similar area as yours on my driver side floorboard on my new 82. I just bought a Miller 180 and we shall see how welding that thin floor metal will go. Soon it might be time for a tig
Keep up the great work!
Old 07-06-2010, 02:04 PM
  #117
85toyman's Avatar
subscribed! Nice First Gen
Old 07-06-2010, 02:32 PM
  #118
Philbert's Avatar
No Udpates since March
I miss the progress and the great photos.....can you at least give us a teaser?
Old 07-06-2010, 03:52 PM
  #119
CitrusTheDragon's Avatar
looking forward to more info
Old 07-06-2010, 05:15 PM
  #120
toyospearo's Avatar
I need some inspiration for my 82!
UPDATE UPDATE!!
Quick Reply: bindergirl's 1981 Pickup Build-Up Thread "The Perkulator"
