Parting out 1992 and 1993 V6 4Runners Winnipeg, MB
Located in Winnipeg, MB just north of Grand Forks.
The 1992, full load, sunroof/PDL/PM/PW/AC etc., 192,000 km (~110,000 miles). Sunroof controls, master cylinder sensor, couple of window motors gone, the rest is still there. Auto 3VZE.
The 1993, bit of a stripper, manual windows, no AC, etc. 323k but some newer parts on it or at least it looks like it (rad, etc.). Seats, passenger side rear door and panel, centre console, stereo are gone. Manual 3VZE.
Also have other 3VZE and 22RE parts still around as well (like new Enginebuilder timing kit, alt, fuel injectors, etc.).
Prices to follow as I pull the stuff off.
Some stuff from before...
Cupholder - 10
Rear Window Relay - 25
22RE fuel rail with injectors - 50
3VZE fuel rail with injectors 50
ECU - 40
Cupholder - 10
ECU - 40
I thought it was cold in southern nevada at 50f - lol!!
I'm looking for the top end wire harness - fuse box to fuel injectors and water temp/pres sensors - reed valve and that 3 hole vsv that mounts next to the reed valve on the air intake.
my 4runner is a 95 vz-e 4wd AT - so the harness will have the knock sensor
My bad vital22re.
Yeah it's been going to down to around 0 F still some nights here, the highs are around 30. When I start tearing down the '92 (hopefully this week) I'll check this out for ya.
Sent you a PM.
Some stuff from the engine bay of the 1993...not selling this particular lower intake but the one from the 1992 should be good when I pull it.
The truck had a wonky idle so I'm not sure if it was a bad TPS or what.
Upper intake manifold - 20
Throttle body/w TPS - 20 note: I have not tested the TPS so it may be bad, TB itself is still functional
Fan clutch - 20
Evap canister - 15
Distributor - 20
Coil and igniter - 15
Interior pictures on the 1992.
Fan clutch - 20
Evap canister - 15
Distributor - 20
Need a part from your 1992 4runner
Hey, I'm interested in the cap for the window lock button on the driver side door of the 92. My girlfriend vacumed ours up at the carwash years ago and I've always wanted to replace it. I'm thinking $10 plus I'll pay for the shipping
I'll try and get you a picture or two in the next couple days of what is on there right now.
The grey '93 is gone so all I have left besides what I took a picture of above is the ECU and the gauge cluster. Everything else I left on the truck as it wasn't worth it for me to pull it the way my schedule is. I still have the whole '92 to pull apart for interior pieces and other things yet.
