Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
my other 4x4, purchased in 1993
Old 09-24-2021 | 10:50 AM
wallytoo's Avatar
the cj5 in my avatar. it's a '75. when purchased, it had totally worn out tires, and clearly had alignment issues. basic setup (stock mostly): dana 20 transfer, dana 30 front/dana 44 rear 3.73 gears, borg/warner t-14 3-speed, 1bbl 258, mechanical clutch linkage, unknown high-back bucket seats, soft top, fiberglass body and fenders, original frame, hood, grille, and dashboard, a later (after '75) windshield frame.
lots of camping trips, jeep rides, covered bridge trips, etc over the years.
first thing i did was buy new tires, some 31x10.5x15 remington wide brutes - at the time, i didn't have a lot of off-road experience, and tires were tires. over the years, as the tires wore out, i replaced them with (in order), 33x10.5x15 swamper radials, 34x10.5x15 swamper LTBs (used), and finally 34x9.5x15 swamper bias ply. i've put over 100K mile the jeep, too. changed the clutch twice, then decided to swap in a 4 speed. so, i added an np435.and changed out to a hydraulic clutch setup (much, much better). soon after that, i put in a lock-right in the d44. i quickly decided that drum brakes all around weren't good enough for wheeling, so i swapped in a front disc setup from a later cj.
the np435 4-speed and novak tranfer case adapter
night wheeling on a local road (yes, this is the road, not a trail or next to the road)
same location. i don't like mud at all, it covers everything.
i know a lot of you don't like jeeps, but in 2wd low, i can access more places more easily than i can in my 1st get 4runner, which has open diffs. anyway, i've put significant off-road miles on the cj. however, the frame was getting pretty bad, and i began the process to replace the frame in 2013 (which happens to be when i acquired my first '87 4runner). so, not much happened in the years since, other than i completely disassembled the jeep, and all of the parts are either in the garage or in the storage place above the garage. i also collected a few new parts to replace some of the beat up stuff that was on the jeep - new plastic (and bigger) gas tank/sending unit, winch, new soft top, new clutch. and most importantly, a new '74 frame (well, in very very good condition) and a wrangler (yj) spring conversion kit from rocky road outfitters.
wheeling OFR in massachusetts
wheeling a road closer to home
probably a 4th of july trip some years ago
The following users liked this post:
SomedayJ (09-24-2021)
Old 09-24-2021 | 02:27 PM
wallytoo's Avatar
pulled it apart about 7 years ago, once the garage was built.
the old tires that came on my 4runner (so i could roll it around in the garage)
a few more upgrades visible - buick hei distributor and weber 32/34 2bbl
hydraulic clutch master
Old 09-24-2021 | 02:31 PM
wallytoo's Avatar
the "new" frame
straight, rust-free
the rocky road spring hangers just set in place, not attached yet
no extra holes, no dents, no bends
Old 09-24-2021 | 02:33 PM
wallytoo's Avatar
beat old frame, rusty and patched
engine removed
plenty crusty
poor shock mounts
well-used
Old 09-24-2021 | 03:16 PM
wallytoo's Avatar
resting place for 7 years
also became a storage unit for 4runner parts and other things...
having the engine crane and engine stand made things a bit easier, too
spare motor, did scavenge a few things from it
Old 09-24-2021 | 03:19 PM
wallytoo's Avatar
changing a few things
new intake & exhaust mainifolds
a true 2bbl vs the 1 1/2 bbl original
going to have to figure out a few of the extra vacuum lines/ports etc
Old 09-24-2021 | 03:22 PM
wallytoo's Avatar
the transmission, x-fer case, and bellhousing
Old 09-24-2021 | 03:25 PM
wallytoo's Avatar
the new tank
bigger
and came with a new sending unit installed
Old 09-24-2021 | 03:28 PM
wallytoo's Avatar
exercising the old dodge 1.5-ton - a friend replaced the axle u-joints and seals on the dana 30 front axle, as well as the pinion seals/bearings, etc - this was the return trip.
secured for the voyage
not a bad 70 mile round trip in the '48
i don't think i approached capacity on this load...
Old 09-24-2021 | 03:33 PM
wallytoo's Avatar
which brings the project to the "putting it together phase"
i had to add stock hangers
and then trim them/drill them
so that the rocky road hardware would have someting to attach to/locate off of
solid mounting
and thicker than the frame itself
Old 09-24-2021 | 05:45 PM
millball's Avatar
What's the engine?? AMC 258???
I've run those in Scouts.
Nothing more heavy duty than a New Process 435!!
Old 09-25-2021 | 03:18 AM
wallytoo's Avatar
yes, 1bbl 258 originally. now a 2bbl with the swapped manifolds. i agree that the np435 is heavy duty, especially in a cj. it has been the single best modification i’ve made, because of the lower gears. 1st is 6.68:1 (lower than a t-18) and reverse is 8.5:1 (almost too low). i remember wheeling with some new folks and doing the hard section in reverse because of the slow speed control.
the 258 is pretty sturdy in its own right. 7 main bearings, not really fuel efficient, but it will run forever with normal upkeep. similar to the 22re. as much as i like my 4runners, the cj is my favorite vehicle. time for it to be back on the road.
Old 10-03-2021 | 03:42 PM
wallytoo's Avatar
cleaned the chasiss with oil/wax remover, rubbed it down a few times, let it dry, then painted two coats of por-15 chassis black on it. to this, i top-coated with pratt & lambert gloss white (again two coats).
once the paint dried, i could "permanently" attach the spring conversion hardware:
the unpainted patches are for ground points/attachments - especially important with the fiberglass body. i have to run extra ground wires from fixtures/tie in points on the dash to the frame. these patches will get painted with the same paint as for the finished portions.
SomedayJ (10-26-2021)
Old 10-03-2021 | 03:59 PM
wallytoo's Avatar
flipped it over, and attached the leaf springs to the frame:
axles under it, too
first time it has been "rolled" since 2013
still have a few loose ends with the suspension to take care of, but it's closer
Old 10-12-2021 | 05:36 PM
wallytoo's Avatar
had to ditch the larger plastic tank & skid plate, just didn't fit. would need too much fabrication for me to handle. soooo, back to the stock tank (brand new).
shiny!
new calipers, too!
Old 10-26-2021 | 07:47 AM
sametoce's Avatar
Can't wait to see the next update.
Old 11-01-2021 | 03:54 PM
wallytoo's Avatar
suspension installation completed
the frame mounts for the engine are installed, too.
Old 11-01-2021 | 03:55 PM
wallytoo's Avatar
putting the rear bumper on
friend made the bumper for me years ago (traded some maple syrup for it).
ties the bumper into the frame really well; had to make a notch through the original rear crossmember for the steel bar to pass through.
Old 11-01-2021 | 03:59 PM
wallytoo's Avatar
getting the transmission, transfer case, and bellhousing ready
crane makes it easy to set the unit on the transmission jack
strapped to the jack; ready for the engine now!
Old 11-01-2021 | 04:00 PM
wallytoo's Avatar
sitting on the crate for most of the last 8 years
Quick Reply: my other 4x4, purchased in 1993
