Wanted: Wiring harness for 1990 Toyota Pickup 22re 4x4
Old 09-07-2007 | 04:36 PM
vietsol's Avatar
I'm looking for a wiring harness for my truck. It's wiring is all cut up and it barely runs. Half the wiring isn't even connected. It was all chopped and they tried to re-do it til it ran. So if anyone has a wiring harness that's compatible with the 1990 22re 4x4 truck, that'd help a lot!! Thanks.
Old 09-08-2007 | 04:13 AM
onefast66nova's Avatar
I have one for an 85 SR5 with a 22re. Not sure if they are the same though.... Bill
Old 09-08-2007 | 04:33 AM
knucklehead38401's Avatar
Is it a auto or manual? Do you need the engine wiring?
Old 09-08-2007 | 11:35 PM
vietsol's Avatar
It's a 5spd manual. I think it has to be 89-92 to be compatible. Though I could be wrong.
Old 09-09-2007 | 11:17 PM
vietsol's Avatar
Yeah, it's the engine wiring. Got one laying around by chance? ^_^
Old 09-10-2007 | 08:07 AM
Well I have a 85 22re 5-speed if you find out it will work. Bill
Old 09-10-2007 | 09:01 AM
vietsol's Avatar
85 will require the entire chassis wiring
Old 09-10-2007 | 05:43 PM
I'm going to look through some boxes tomorrow and I'll let you know.
Old 09-10-2007 | 06:00 PM
vietsol's Avatar
awesome. Keep me posted. ^_^
Old 09-11-2007 | 07:41 AM
Look at your ECU and tell me how many pins are located on it. It should tell you on top how many it has.
Old 09-11-2007 | 08:05 AM
I've got 2 one has a 26 and 16 pin connector, and the other has 10,18, and 14 pin connector.
Old 09-11-2007 | 12:12 PM
ToyotaGuru's Avatar
Wiring Harness
Pre 89's are not going to plug into your fuel injectors or TPS for staters.
I think you have to find 89-92. IIRC our Friends at Toyota change the harness again for 92-95 with diffenet igniter and dist connectors as well.
Old 09-11-2007 | 01:59 PM
vietsol's Avatar
it's 10 18 14
hoping to find one that mated to the ecu with part number 89661-35150
Thanks for the info. This will help in my quest greatly so that I don't have to rewire stuff. ^_^
Old 09-11-2007 | 06:28 PM
Ok, I have one but it's a auto harness which will work, all you will have to do is jump a wire on the harness itself for the starter, which I can do for you.
Old 09-12-2007 | 08:54 AM
vietsol's Avatar
How much do you want for it? Would the reverse lights still work too? I've seen problems with reverse lights when using auto harness on manual vehicles. Let me know.
Old 09-12-2007 | 09:39 AM
dlbrunner's Avatar
I have a complete one from an 89, 4x4, 5spd. Plus computer
Make me an offer
Old 09-12-2007 | 04:28 PM
vietsol's Avatar
Make me an offer
Do you have ECU too? part number 89661-35150
PM'd
Old 09-14-2007 | 04:17 AM
I dont think the reverse lights would work.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
GorgeRunner
06-27-2015 07:01 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
bprice0077
06-25-2015 07:36 AM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: Wanted: Wiring harness for 1990 Toyota Pickup 22re 4x4
