Toyota Truck & 4runner Parts "anything U Need"
#204
Manual locking hubs
Hey lookin for (if possible) just 1 manual locking hub, I'll take 2 if I need to. Just wondering the cond. of them, if they were cleaned and so forth. Let me know how you do business and the availability, and you'll have a buyer.
Thanks,
- toyodaman8587
Thanks,
- toyodaman8587
#205
Hey I was looking for (if possible)1 Manual locking hub, I'll buy two if need be. Wondering about the cond. of them, if they've been cleaned and so forth. Just let me know how you do business and the availability and you got yourself a new customer.
Thanks,
-toyodaman8587
Thanks,
-toyodaman8587
#207
81 82 toyota truck parting out tons of parts
I AM PARTING OUT A COUPLE OF THESE TRUCKS FROM 79-83 I HAVE ALL KINDS OF PARTS:
SOLID AXLES COMPLETE $350
REAR AXLE $200
TRANSMISSION $350
TOP SHIFT T-CASE $150
22R ENGINES $700-1200 DEPENDING ON MILES
WOOD GRAIN DASH $100 NO CRACKS
TOP DASH PAD ONE SMALL CRACK $100
DOORS $80 EACH
DOOR PANELS $55 EACH
FENDERS USED $65 OR $85 NEW
CABS $300-600
FRAMES $400-700
SPRINGS $40 EACH
BLOWER MOTOR $30
HEATER CORE $45
GLOVE BOX $25
TILT STEERING COLUMN $40
STEERING WHEELS $20-50
LOTS MORE STUFF PLEASE TELL ME WHAT YOUR NEEDING????
828-231-5715 OR 828-329-1097
bjbcase@charter.net
REAR AXLE $200
TRANSMISSION $350
DOORS $80 EACH
CABS $300-600
FRAMES $400-700
SPRINGS $40 EACH
BLOWER MOTOR $30
HEATER CORE $45
GLOVE BOX $25
bjbcase@charter.net
#209
wire harness
I see you have complete wireharnesses. I have a 95 3vze that I just replaced the engine in. I am sure I have a wiring issue and my left 3 injectors are not really firing. do you have a complete wiring harness (with decent injector connectors) for the 3vze auto 4x4?
Jake
If possible, could you email me at jloewenheim@gmail.com?
Jake
TOYOTA 4 RUNNER & TRUCK PARTS "ANYTHING"
I part out Toyota Trucks & 4 Runners pretty regular so I have all kinds of stuff available..
3rd Members (4.10, 4.38, 4.30, 3.58, 3.90) $150 each 2WD OR 4WD
AXLE HOUSINGS FRONT $100 REAR $50
V6 COMPLETE REAR AXLE 4.10 $300
IFS FRONT AXLE $100 (center chunk assembly)
Solid Front Axle Complete Hub To Hub $300
Rear Axle 86-95 $250
Rear Axle 79-85 $200
Calipers $65 for the set
Bench Seats $75 (blue or gray) 2WD OR 4WD
90 X-Cab Split Bench Seat with Armrest GRAY $150
4 Runner Complete Rear Seat $150 with all hardware (gray or brown)
Top Shift T-case $150 obo
4 or 5 Speed 2WD Transmissions $250
4 Runner Automatic Trans & T-case $200
w56 Transmission & T-case $400
g52 Transmission & T-case $350
22RE Complete Intake $125
Truck or 4 Runner Gas Tanks $50 each
20R Carb $75
Driveshafts FRONT $75 REAR $50
Doors $50-75 each
Fenders $50 each used or New @ $125
Hoods $50-100 depending on condition
Beds $150-300 depending on condition
Regular Cabs $300 & X-Cab $600
IFS Parts Upper Arms $40 each & Lower Arms $65 each
20R 22R & 22RE Cylinder Heads $99 each
MAF Sensors $75
20R & 22R Intake $75 each
Sliding Rear Window $65
79-83 FRAME $500
Aluminum Wheels $40 each no 16"
Steel Wheels $20 each no 16"
Tailgate $65
Locking Hubs $100 for the set (IFS or Solid)
20R 22R 22RE Exhaust Manifolds $40 each
Truck or 4 Runner Complete Wiring Harness $100 each
4 runner Tops $150 each (red, black, & camo)
Brown, Gray, Blue complete dash kits $75
Power or Manual Door Panels $25-50 each depending on which style you need (gray, beige, blue & some SR5)
2WD Front Suspension Parts (let me know what you need?)
4 Runner & Truck A/T Shifter $65
22R Oil Pan $30
22R Front Cover $50
Flywheel $50
Windshield Trim $50 for the set
Instrument Clusters $50-100, I have a 90 x-cab with TACH but thats the only tach style i have...
Power Steering Parts (tell me what you need)???
Complete Steering Columns TILT $75 & no Tilt $50
Crossmembers $50 each
84-88 Grilles Chrome or Black $60
Tacoma Grille Chrome $75
T-100 Grille Chrome $125 also have a bumper & valance available
90-95 Truck Grille $100 also have a bumper & valance available
84-88 4 Runner Interior Trim all kinds of stuff??
84-88 Truck Interior Trim all kinds of stuff??
84-88 Truck or 4 Runner Complete A/C Kit Compressor & Brackets, Evaporator, A/C Hoses, & Condenser $199
90-95 V6 Truck Complete A/C Kit Compressor & Brackets, Evaporator, A/C Hoses, & Condenser $199
Alternators & Starters $40 (let me know what you need it from)
Air Cleaner Boxes $30
Wheel Hubs Solid or IFS $30 each
You can contact me 828-231-5715....I live in Candler,NC which is 15 min WEST of Asheville,NC
20R Carb $75
Doors $50-75 each
MAF Sensors $75
79-83 FRAME $500
Tailgate $65
22R Oil Pan $30
22R Front Cover $50
Flywheel $50
#210
What parts do you have? I need the woodgrain center trim, seat, slider window lock, throttle cable cam (peice on valve cover and peice on intake manifold), and coil setup.
Thanks Jason
Thanks Jason
