ONE OF A KIND 2002 Custom Built Toyota Tacoma $21,495 Pismo Beach CA **$OLD**
Old 12-04-2017 | 09:06 PM
PismoJoe's Avatar
Selling a one of a kind custom Toyota PreRunner. Built by Central Coast PreRunners in Arroyo Grande, CA.
142k Miles 5 Speed 4WD 3RZ SR5 Tacoma. Power Windows, Door Locks and Mirrors. Cruise Control, Ice Cold A/C, etc.
No expenses were spared during the long build of this truck. Very well maintained. All services up to date and Toyota Parts Always used for repairs. I am the second owner. Clean carfax. Registered thru September of 2018. Smogged and ready to go! Over 40k Invested in this truck.
This truck truly has it all! Ready to drive across country or on any dirt road you can throw at it.
This is one of the cleanest Tacomas/PreRunners around. Truck was completely professionally painted after fabrication was completed by Sierra Auto Body in Grover Beach.
Specifications:
-Power Doors, Locks, Mirrors, Windows, Cruise Control
-Factory Keyless Entry/Alarm (2 Keys, 2 New Genuine Toyota Remotes)
-142,XXX Miles, registered thru 9/18, smogged and ready to go!
-Clean Carfax, Always garaged, maintained by ToyWorx Automotive
Suspension/Steering
-Total Chaos 4WD Long Travel Kit
-Total Chaos Coil Bucket Gussets
-Total Chaos Spindle Gussets
-Total Chaos Heim Joint Steering
-Icon 9" x 2.5" Diameter Coil Overs (Front)
-Icon 9" x 2.5" Diameter Omega 2-Tube Bypass Secondaries (Front)
-Deaver F67 Leaf Pack (Rear)
-Icon 18" x 2.5" Diameter Zeta 3-Tube Bypass (Rear)
-Front maintains 4WD with 14” of wheel travel, Rear is strapped at 18” of travel
Body
-Central Coast Prerunners Front Engine Cage, Core Support, Inner Fenders
-Central Coast Prerunners Aluminum Paneled Wheel Wells
-Central Coast Prerunners F&R Bumpers/Bedside Supports
-Central Coast Prerunners Rear Bedcage/Boxed & Gusseted Frame
-Glassworks Fiberglass Hood, Fenders, Bedsides
-3 Baja Designs 8" LaPaz HID Lights (2 Driving, 1 Pencil)
-3” Front Wheel Tub, Tig Welded and Sealed
-Crown Steel Braided & Extended Brake Lines F&R
-Black Grille/Corer Marker Light Swap w/ OEM Toyota Grille and Corner Markers
-Complete Paint Job By Sierra Auto Body (Stock Color 040)
-15x8 Mickey Thompson Classic Locks
-Brand New 33x10.5 BFG All Terrains K02’s and Alignment by Tyerman’s
Drivetrain
-3RZ-FE with new cylinder head and Toyota Gasket Set at 110k miles
-Factory Toyota ‘Mini Header’ Kit
-30k service just performed. Synthetic Fluids, Denso Spark Plugs, Valve Adjustment
-W59 5 Speed Transmission. OEM Aisin Clutch Disc, Pressure Plate, Nachi Release and Pilot Bearings done at 120k miles.
-Factory E-Locker Swapped Rear Axle Housing. Wired for use in 2 or 4WD.
-Modified Tundra Front Axles with Manual Hub Conversion (One of a Kind, Tundra Inner shaved joints, Tacoma Manual Hub outer joints)
-4.88 Gears Front and Rear by American Gear in SLO
-Front and Rear wheel Bearings replaced when differentials were re-geared at 130k. At the same time new front brakes (pads and rotors) and new rear brakes (shoes and drums) were installed.
-K&N FIPK Intake. Smog Legal.
-Flowmaster 40 Series, Cut & Dumped
-Complete window tint by Velocity Tint in September, Along with new front windshield.
Interior
-MasterCraft Baja R/S Front Seats
-Complete Custom Stereo (Sounds Excellent!)
-10" JL Audio Stealthbox, Pioneer Bluetooth APP ready CD Changer w/ Aux input as well, Sony 500 Watt Single Channel Amp (Sub), 1500 Watt 4 Channel amp powering JBL 3-Way Speakers F&R With Crossovers, Digital Power Capacitor.
Old 08-19-2018 | 09:01 AM
joesgarage's Avatar
Sold?
Old 08-19-2018 | 11:56 AM
PismoJoe's Avatar
Truck is SOLD thanks
arlindsay1992
07-16-2018 06:31 PM
BigMike
Marlin Crawler
10-03-2017 07:50 AM
LS1Steve
02-27-2007 07:31 PM
funjumper
07-24-2006 10:45 AM
