Is chunking normal for MTs...
Old 08-11-2004 | 06:21 PM
timber725's Avatar
My Firestone MTs got a lot of nicks and cuts from the Big Bear trip. Also, I lose some rubber off the lugs.
Is this normal? Ahriman has the same tires, and I noticed the same problem with his.
Should I be concerned? Does MT/R have this problem?
Old 08-11-2004 | 06:52 PM
kyle_22r's Avatar
yeah, chunking is just something you have to deal with when you have MTs
Old 08-11-2004 | 07:12 PM
BruceTS's Avatar
Yes that is very normal for tires that have played on the rocks.
EDIT* I should have said any type of tire....
Old 08-11-2004 | 07:14 PM
Nitro Hotpants's Avatar
I've got the same problems with my MT/Rs, I'd say just expect this to happen.
be happy you havent punctured a sidewall yet
-Casey
Old 08-11-2004 | 07:38 PM
r0cky's Avatar
yes, this is very normal. just a week or so back someone else posted a similar question, and general concensus was - on an m/t, chunking is to be expected.
Old 08-11-2004 | 07:57 PM
Pretacopower's Avatar
You should see my Revo's after spinning them on the hill on the Big Bear trip.
Not pretty
Old 08-11-2004 | 08:12 PM
jimbo74's Avatar
any tire subjected to uses off road or even crappy roads will exhibit damage.... enough said....
Old 08-11-2004 | 08:45 PM
cubuff4runner's Avatar
Each of my super swampers is missing at least 3-4 whole lugs and at least 5 more are partially gone. Happens with all tires however, the more aggressive the tire the more surface area and access there is to the side of the lug to rip it off.
Old 08-12-2004 | 12:40 AM
timber725's Avatar
What does it affect when you start chunking? Ride quality? Noise level? traction?
Old 08-12-2004 | 04:32 AM
HondaTec521's Avatar
Tire Balance !
Old 08-12-2004 | 08:51 AM
Good Times's Avatar
loi, i think you should just donate them tires to me and the wheels
actually just get them balanced and rotated after each run you do. I always do and if your alignment goes to whack after a run, get that done too!
Old 08-12-2004 | 10:29 PM
85RedRunner's Avatar
It also has to do with the fact they they are a softer compound which is the same reason they wear down faster then regular tires.
Old 08-14-2004 | 03:20 AM
Birdman's Avatar
Don't you think that's a bit excessive? Unless you're losing major chunks of rubber and experiencing vibration, why would you need to do this? I just don't see the logic in the suggested frequency. Sounds more like a waste of money to me.
Old 08-14-2004 | 08:35 AM
Good Times's Avatar
welp I get unlimited balance and rotation w/ discount tire/america tire so i might as well take full advantage
i know loi got it at the same place too so i figure he might as well do the same thing.
Old 08-14-2004 | 11:09 AM
Tacoma Dude's Avatar
My tires are siped so I see chunking all over the place
(small bits though)
Davebarbier
11-03-2015 04:28 PM
bradahman
10-01-2015 10:24 AM
hiluxinargentina
10-01-2015 12:12 AM
voiddweller
09-29-2015 12:21 AM
charlie_fong
09-27-2015 11:06 PM
