94 Toyota with 4in lift. Tire size?
I'm having a really hard time figuring out what tire size I can get on my truck without rubbing. Also what wheel size? Should I go with 16in or 17in wheel?
Did you search? 28-33" tire will likely never rub. 35" tire, possibly might clear with zero modifications, but likely slight mods. wheel size is up to you, why limit yourself to 17s? I think 22s might fit
Break out the cutoff wheel, sawzall, and sledge. You can fit any size tire your heart desires on that lift. Go big or go home.
Or find a buddy and test fit. Or search topic very common, there's even a sticky with similar title.
Of course your intended use will effect size. Mall crawler vrs wheeler.
Tristo
04-24-2016 02:29 PM
