Camping, Expedition, & Overlanding Gear Discussion pertaining to outfitting yourself with gear for the great outdoors
irab88's 1983 Coleman Sun Valley Build-Up Thread
Old 04-02-2012, 05:44 AM
  #361
irab88's Avatar
out with the old!
aluminum glued to syrofoam glued to plywood... bleh.
good bye!
Old 04-02-2012, 12:15 PM
  #362
ChefYota4x4's Avatar
I LOVE TRIPS TO THE DUMP! hehehe... Last time I visited my pops, my brother and I got to throw toilets off this cliff into bins 40ft. down! lol... 'BASHHHHHHH'
Hope all the details work out without any drama... I'm not FULLY understanding the "butt" and "Lap" lingo(but looking it up and learning, QUICKLY, lol).... but I don't want you to get all wet or ruin any of that hard work inside, either, ....so I'm watching and I'll gladly post anything I find when I cruise the 'Camper' Sites, lol.
Old 04-02-2012, 04:29 PM
  #363
irab88's Avatar
butt joint is when the pieces come together at the edges. lap joint is when the pieces overlap a little. joggle is a small bend in one of the pieces of a lap joint that allows both pieces to sit flush on one side.
one thing at a time... seems to be working well so far, so i guess i'll keep it up.
Old 04-02-2012, 10:41 PM
  #364
aviator's Avatar
You coulda done without the joggle and just have the overlaps run down wind travel direction wise... or you coulda made a jig with a plane and 2 2x4s and variable arc swing press...
if dude can tig the seams for you no worries... a plate joint would be good too... maybe even better...
I'd drill out the holes in the plate than use it as a pattern to drill out the roof... maybe borrow a few clecos to keep it in registry... after all the holes are done run a bead of urethane down both hole lines of the plate and cleco/rivet it together... the urethane will bond and seal the parts together...
Old 04-05-2012, 04:14 PM
  #365
irab88's Avatar
new toys
Old 04-06-2012, 08:57 AM
  #366
aviator's Avatar
Air riveter eh? sweet
Old 04-06-2012, 09:08 AM
  #367
Score! That will make this and future jobs much easier, eh?
Old 04-06-2012, 09:09 AM
  #368
irab88's Avatar
it'll be especially helpful in the trim pieces, as i don't need to force the lever, putting stress on the raised roof
Old 04-07-2012, 05:51 AM
  #369
irab88's Avatar
500 rivets and counting
Old 04-07-2012, 08:25 AM
  #370
irab88's Avatar
575 rivets later, and the roof is 90% done. just need to add all the trim pieces and seal it
Old 04-07-2012, 09:28 AM
  #371
xxxtreme22r's Avatar
So does that mean you have another 64 rivets to go? I can't believe you did most of those other rivets manually.
Thought you were doing it with a gun already.
Old 04-07-2012, 09:47 AM
  #372
irab88's Avatar
64 sounds a bit low, maybe more like 100-150 more... so, 80% finished then
and i think i'm done for the weekend. i'll get the rest of the trim pieces up later, but my trailer is good to go home now.
i'll get pics up as soon as i clean up here
Old 04-07-2012, 11:34 AM
  #373
irab88's Avatar
Old 04-07-2012, 11:37 AM
  #374
Dayummmmmmmm! That's-alotta-rivets! lol. Great job, Ian. You decided on color for all that yet?
Old 04-07-2012, 11:48 AM
  #375
irab88's Avatar
no, but i found some stuff for aluminum roofing that comes in white. "kool seal" is a rubberized coating for aluminum rv roofs, and is available locally for fairly cheap
Old 04-07-2012, 11:09 PM
  #376
aviator's Avatar
Looks great but dude you gotta do something about securing the tank... bungees ain't gonna cut it long term... on our old trailer we had an angle iron frame like you have and we drilled two holes either side of the frame and thru the steel stand on the bottom of the tank and bolted it to the frame with a pair of 3/8 bolts and nylok nuts... that thing was on there but good... but was still easy to remove for filling....
Old 04-08-2012, 12:16 AM
  #377
Nice!
Old 04-08-2012, 12:03 PM
  #378
irab88's Avatar
aviator, you make me lolz...
the cords are there because i put them there for transport. the tank has 2 steel j-hooks. it ain't goin' nowhere
Old 04-08-2012, 02:19 PM
  #379
irab88's Avatar
just a pic. bringing it home yesterday.
Old 04-08-2012, 06:13 PM
  #380
aviator's Avatar
Looks good Ian...
Quick Reply: irab88's 1983 Coleman Sun Valley Build-Up Thread
