Elvota's 3.4 swap
#262
If the URD setup just plugs in, maybe it needs the O2 sensor to be working as it modifies the signal on the way back to the ECM? Just guessing.
#263
I don't know much about the URD setup, but the Jason setup bypasses the signal side of the O2 sensor, putting the signal at the correct waveform full time.
I don't know a lot about it either, like you said "could be voodoo magic for all I know". Electron flow is not my specialty LOL.
#264
Taped up.... dang it, new I forgot something.
Note: Sacrifices are most likely unnecessary to keep the "JasonBox" working.
#266
No body lift... just cut the hood. There is a pic of it on this thread somewhere, but I'll post it again.
I had to enlarge it slightly from this picture. Engine torque and such on the trail. Will most likely cover the hole soon with a hood scoop of some sort.
#267
Awesome thread!!! This is exactly what I was thinking of doing eventually. Great job on the detailed blow by blow write-up and photos! So how long did this entire project take you? And I can kinda tell why you had to cut the hood, what exactly is that thing that is sitting right under that hole in the hood?
#269
#270
I just spent an hour reading through your post. I was so stoked to hear it fired lol. felt like i was watchin some reality show. and im considering doing it myself now. i have 2 cylinders out on my 3.slow so we'll see. i just have to locate a 3.4. I really dont have any expierence pulling motors but ill learn i gues... lol. but i was wondering what was your total at the end of the project?
#271
Total... as in cost wise. I was able to sell the 3.0 and related accessories after my swap which took about $850 off the price. My 3.0 was in great shape with lots of newer parts and recent maintenance. Could have probably gotten more... but was glad to get some space back in my garage.
I got the 3.4 with accessories for around $1200. I added headers, timing belt, spark plugs, wires, clutch... various bits and pieces for $1200 more (give or take). Wiring was next to nothing as I did it myself, as well as all labor besides turning of the flywheel.
I know I forgot some costs, but I'll say when it's all said and done I was at or under $1600 out of pocket for the swap. The key will be your donor motor price and how much you have to get from ORS. If you can handle all the labor and wiring... it's a fairly cost effective way to go for a huge upgrade in performance. If you can't, your budget should be closer to $5000.
Keep in mind, I am a bicycle mechanic with almost zero electrical experience before I started this project. If I can do it... so can most.
Seeing that I spent close to $1300 on just the SAS kit... I considered the swap a bargain.
#272
i'll be cutting alot more than that the first gen hood is not raised as much as that bummer its still going in just need a hood scoop!
#273
I am looking for a scoop as well. Let me know what you find.
#274
thought I'd try my hand at fiberglassing first but if thats no good i like the 99-04 Ford Mustang F150 factory Roush hood scoop see it here but it is like 150$ so i don't know about spending that kind of money, i can't believe ORS hasn't added it to the kit lol they could charge $500 more lol. If we can make a cross over pipe we can make a hood scoop!
#275
Look at this cheap sucka :
http://cgi.ebay.com/ebaymotors/RAV4-...1998QQtcZphoto
This one also looks like it might work:
http://www.amazon.com/Auto-Ventshade...196902&sr=1-17
Or maybe one of these....:
http://www.jegs.com/webapp/wcs/store...52524_-1_10355
Bit more spendy:
http://www.fiberglass-hoods.com/hood-scoops.shtml
I have been looking for a while. Not sure which way to go.
Bit more spendy:
#276
Here is a thread with a bunch of discussion and some other links to options. Some of the links are probably dead by now though. https://www.yotatech.com/forums/f2/s...-scoop-103436/
Also one more if you're made out of money: http://www.church-steeples.com/auto.htm
#278
Just have to splice the box in somewhere between the ECM and the secondary O2 sensor. I chose under the hood as it was offered some protection from the elements there.
#280
Elvota, I'm finishing up details like routing stuff today, and remembered you used a Marlin brake line for your clutch. I hooked up the stock line with the ORS bracket today, and I think I like your way better. What was the original applilcation for this line from Marlin?
