plugs look okay/clean to me. how do your plug wires look? you replace your fuel filter? as far as your obd2 port, are you running power to it on the purple wire? should be 7.5 amp fuse to it. that was my problem.
How was your maf?
I have a k&N filter on mine and the damn oil sucks off the filter element and makes it run like crap.. Cleaned my maf and its good to go. |
I think the reason I was getting an error was because I had hot wired my STA wire on the ECU, so when I would turn on the key to get codes the ECU thought that I was trying to start it. That was also why it was running like crap, because my ECU thought that I was constantly trying to start it, which probably changed timing and what not.
