3.4 swap 2000 tundra ecu auto
im about to do my second swap.
is anyone out there running this setup
3.4 swap 2000 tundra ecu auto 2wd, we dont have smog test here. i going to be using a 5 speed manual behind it.. thanks
i was just wondering if it was possible because my first swap i use all manual ecu and repinned auto harness.. thanks i just dropped the motor in today going to do the wirings now will let u know how it goes..
i am running an 98 auto ECU with a manual trans. just find the NSS (neutral safety switch) wires and solder them together. other than that everything should be just the same as wiring up with a manual ECU. (assuming you are using the auto harness, no need to repin)
i never understood why everyone always said you needed the manual ECU.....
i have read number #5 but i heard the newer ECU revs out lower when its in park or nuetral.. Found out for my self today got it fired up and rev it pass 5,000 so it should be fine..thanks
06-01-2021 01:51 PM
mengquis
07-13-2015 10:39 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
