replacing rotors
Senior Member
replacing rotors
Well the time has come to replace these ole warped rotors with some fresh new ones. I was just wondering if anyone has a write-up on how to change rotors on a 3rd Gen. How difficult is the process?
Re: replacing rotors
Installation is the reverse.
If you have an impact wrench for removing the lug nuts, the whole thing will take you less than ten minutes a wheel.
wow! doesn't sound tough at all!
[list=1][*]Do not allow the caliper to hang from the brake line.[*]When the calipers are off, do not, under any circumstances step on the brake pedal... it will over extend the slave cylinders.[*]If the caliper doesn't want to fit back over the new rotor and you need to push the pistons back a bit, Push BOTH sides at the same time.[/list=1]
That should do you... but all in all it's a no brainer.
Best of luck!
I LOVE your truck!!!!!!
