radiator question
radiator question
the radiator in my truck sprung a lettle leak today. just wondering if there are aftermarket units or am i stuck with a stock replacement. got quotes for new ones from 122.00 - 209.00.
pretty much stock replacement is going to be the best bet... if you have a 4cyl, you can try to upgrade to a v6 radiator.... i beleive all replacement radiators are aftermarket units... probably except for the ones you actually get from toyota..... there are companies that custom make awesome radiaotrs for vehicles, but those radiators can easily run $500
You might be able to patch your radiator, to buy you a little more time. I had this happen to me and was able to keep it patched until I got the new radiator and had the time to take the 4Runner down for a little while.
IMO, I'd swap it out and eat the cost. That way you'll have peace of mind knowing that the core isn't plugged, which could cause overheating and eventually lead to other problems. Aftermarket parts may be cheaper, and if you can, find out whether or not it has been pressure tested.
Troy
Troy
What about http://www.radiatorbarn.com/ ?? Think someone on here used them
I have had good luck with http://www.radiator.com/.
Originally Posted by jayris
North west off road has 3 row heavy duty radiators.
I don't know where your leak is, but my 84 Camry was leaking on the top of the radiator. I was able to patch it with JB Weld. It would hold for a while and then start leaking again. Really wasn't a big deal since it was on the top.
It got to be annoying after a while so I got a new aftermarket one from Advance Auto Parts for $120.00. Its made in China, but fit like a glove.
the1998sr5
15
07-14-2020 08:35 PM
Road Bull
10-10-2015 04:55 PM
TJWilly
07-31-2015 02:05 PM
defrag4
07-31-2015 10:50 AM
Avenged
07-09-2015 07:55 AM
