Help with CODES
Old 05-07-2005 | 01:32 PM
filter's Avatar
Help with CODES
Reporting the following codes OBDII : 99 4runner
P0171 - System too Lean Bank 1
P1131 - A/F Sensor circuit response Bank Sensor 1
Are these codes pointing to a faulty Mass air flow sensor?
Any help or experience with these is appreciated
Thanks
FiLter
Old 05-07-2005 | 01:44 PM
MTL_4runner's Avatar
Thanks
FiLter
Most likely it is your MAF which needs cleaning (usually throws P0171, but can throw others at the same time). In rare cases it may be something else (or could be a MAF which is faulty and can't be fixed by cleaning).
Old 05-07-2005 | 01:52 PM
filter's Avatar
Thanks
How do you clean it?
Old 05-07-2005 | 03:01 PM
dragr1's Avatar
That first code is most likely the maf, I tried cleaning mine, but eventually had to replace it-I got one from a junkyard.
Old 05-08-2005 | 01:49 AM
Tacoma Dude's Avatar
I took my airbox out and sprayed the MAF liberally with electrical contact cleaner.
I saw that there was still some stuff on it and ever so gently brushed against it with a q-tip.
I wouldn't suggest you do the q-tip though...
Old 05-28-2005 | 12:34 PM
filter's Avatar
I tried cleaning the AFM and that seemed to be OK until I eventually seen the light again so I replaced the AMF with a new one.
Now the light is on again with a new code:
P1133 - A/F Sensor Circuit Response (Bank 1 Sensor 1) (Toyota)
Any help or expirience is appritiated
Thanks
Old 05-28-2005 | 01:11 PM
Bob_98SR5's Avatar
filter,
google "OBDII codes"
bob
Old 05-28-2005 | 01:59 PM
filter's Avatar
what do you mean?
I use google for plenty of research.
moparbay
10-06-2015 10:24 AM
bradahman
10-01-2015 10:24 AM
charlie_fong
09-27-2015 11:06 PM
Odin
09-26-2015 07:56 PM
Draven023
09-26-2015 01:41 PM
