Old 04-13-2016, 09:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Electrical Guides
Print Wikipost
97 4Runner..problems starting
Old 06-21-2005 | 07:13 AM
bmwpower's Avatar
From time to time, the truck will not start. Just a click and that's it. Trying again usually does it.
I checked the starter wires for corrosion, but they look fine.
Any idea what it might be?
Old 06-21-2005 | 07:44 AM
bmwpower's Avatar
Wanted to add, yesterday when I tried to start the truck I saw an arch under the ignition cover.
Old 06-21-2005 | 08:09 AM
li_runner's Avatar
It is the starter, search around for topics and your questions will be anwsered.
It is a fairly regular topic around here, I have replaced mine, but the part was on backorder and took a few days.
Old 06-21-2005 | 09:13 AM
pfbmgd's Avatar
Had the same problem with mine two months ago .Took it to a alternator rebuilding shop and had the starter rebuild .Cost me $160 cash including labour .
Old 06-21-2005 | 10:12 AM
bmwpower's Avatar
Looks like you can replace just the contacts per a link I found. I might go that route, especially if it's cheaper.
Old 06-21-2005 | 08:10 PM
george16's Avatar
Yes, it's a lot cheaper. Check out Roger Brown's site for the info in replacing the contacts. It's about 17 bucks from the dealer.
George
Old 06-21-2005 | 08:21 PM
kevin444's Avatar
Yup its the starter just rebuild it instead of buying a new one which would cost like 300 bucks!
Old 06-21-2005 | 08:26 PM
rimpainter.com's Avatar
I bought my contacts from Roger, pulled the starter, replaced them, and had it back in in under 1HR. Works great.
Old 06-25-2005 | 11:59 AM
Bob_98SR5's Avatar
i just had mine replaced though as others have said, you can rebuild it if you have the time. just do it
Old 06-25-2005 | 02:48 PM
4Crawler's Avatar
Usually quite easy to replace the copper contacts inside the starter solenoid. That is usually the cause of the "click":
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 06-26-2005 | 10:37 AM
george16's Avatar
Hardest part is removing the starter itself but you can go the the tech section for the procedure in removing the starter.
George
Doug4320
03-24-2018 11:11 PM
ZONAYODA
07-13-2015 08:17 PM
Poncho0206
07-10-2015 07:21 PM
raiderhawks00
07-08-2015 07:23 PM
Huntingtruckcletus
07-08-2015 06:26 PM
