Old 02-09-2016, 09:55 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
2nd gen 4Runner drivers mirror help please
Old 04-01-2005 | 03:16 PM
Corey's Avatar
Co-Founder/Administrator
Staff
When I bought my rig in Nov. of '98, the drivers lens was always a little shaky in the mirror housing.
I had taken out the screw before and the lens was tight on the plastic plate that sits in the housing, and I did not see a way to fix it.
Well, just a few days ago the whole lens/plate assembly is loose.
When I drive, the mirror is facing the ground.
When I come to a stop, the lens faces up.
These are power mirrors.
I am trying to take the whole mirror off, but it is not cooperating with me.
There are three phillips screws that attach underneath where you grab the mirror to swivel it in when you hit the auto car washes, or for on a tight trail.
The screws are out, but I can not pull the mirror housing off.
What is the trick to this?
I want to see if I can fix it, since Toyota wants $250 per mirror.
TIA,
Old 04-01-2005 | 03:31 PM
gwhayduke's Avatar
Did they use a 3M sealant to keep water out? I tried taking my rear wind deflector off one time to repaint it but found it so tightly sealed to the body that I finally just left it in place. Some of the guys talk about using a hairdryer and dental floss to work it loose. It might work here.
Old 04-01-2005 | 04:00 PM
Corey's Avatar
Staff
I am not even there yet.
I thought you could just take out the 3 screws on the bottom and pull the joint apart.
It is like a ball & socket type of joint.
I called Toyota, and the guy said the whole outer black plastic plate on the outside has to come off, and that means pulling the door panel off from inside, and taking out more screws.
Plus I have tape on Vent Visors, so that is going to screw it up
Old 04-02-2005 | 04:00 AM
Troudt's Avatar
If you can't fix it, I've found a site that sells mirrors very cheap.
http://www.autotruckmirror.com/toy-4runner-95.html
I've haven't bought from them so I don't know how good they are. If you do buy from there let me know as I'm thinking of replacing my chrome power mirrors with black power mirrors.
Old 04-02-2005 | 04:55 AM
Cebby's Avatar
Corey - you just need to pull off that little black triangle inside of the door panel, (not the whole door skin) to access the screws that allow you to remove the mirror from the vehicle. I have a set of mirrors I'm mounting lights and believe I have them apart. Let me see if I can find them and take some pics for you.
Old 04-02-2005 | 05:49 AM
Corey's Avatar
Staff
Thanks Trout for the link.
This here is my mirror according to their pics.
Where it swivels is where I took the 3 screws out of underneath.
I was really hoping I could just lift up and pop it out.
Mike, yeah you can see the black triangular part in the pic above, and Toyota said I must remove the inner door panel to gain access to it.
But if so, I will have to break one of my Vent Visors then, as it is taped to it.
I have spare Vent Visors, as I had to buy a 4 pack a few years back to replace a broken one.
Old 04-02-2005 | 06:35 AM
Cebby's Avatar
Here Corey - all you need to remove is the small trianggle on the inside to get to the 3 screws that hold it on. Pry from the top and then pull it up and out. There is a tongue at the bottom.
The entire mirror comes off like the pic in your post. I couldn't find the ones I have. They are buried in my garage somewhere. Anyway, I wasn't able to figure out how to remove it at that joint - there is a decent spring in there that must be impossible to get back together if you do manage to get it apart.
Old 04-02-2005 | 07:02 AM
Corey's Avatar
Staff
Thanks Mike for the pics.
I hope to attack this today, but the weather here is not much nicer than in your pics.
Since my garage is the great outdoors, I may end up ghetto rigging my mirror with duct tape to hold the lens in place until nicer weather gets here.
Old 04-02-2005 | 10:12 AM
Corey's Avatar
Staff
Done
But with problems.
I need to head to Toyota to get them to fix my window gasket if they can.
When I go to power up the window, it drags, lists the blue panel inside, and will not go all the way up.
I hate working with gaskets and interiors crap.
If it rains, it will get wet inside.
Here are some pics and a vid.
One
The cover you pry off, I used a flat blade screw driver, it worked well.
Two
Cover off, bolts exposed holding housing to outside.
Three
Screw driver used to pry off my Vent Visor which was adhered to frame.
I tried fishing line, but it was to weak.
Also tried dental floss, and it too broke.
Screw driver to the rescue once again.
Four
Dangling in the wind.
Five
I went through all that trouble for nothing, and could save myself a trip to Toyota to fix window seal.
It was the screw in the photo here.
The screw holds the mirror and backing plate in tight so it will not flop around.
The plastic that holds the screw in place is partially broken as seen.
Solution, cram a bigger screw in the hole.
Again, screw driver to the rescue.
I love screw drivers, and if I still drank alcohol, I would have me a couple right about now of the liquid kind
The video, 479.6 KB
Well, at least I know now how to take the whole mirror off.
Just wish I had tried that screw on the bottom first, now my wallet is going to suffer form the wrath of the dealer to fix the gasket.
I hate gaskets, but I love screw drivers.
Pay no attention to all the spooooooge in the pics.
That is from the tree above me, and that black stuff gets everywhere.
Rig needs a bath bad, and some TLC.
Old 04-03-2005 | 04:42 PM
Toddski's Avatar
Uh....hello...Mcfly....
Why didn't you call? You could have come by my place and we could have brainstormed it, well maybe not brainstormed but atleast we could have worked on your rig first then mine. My mirror is shaking also.
06-01-2021 01:51 PM
Jdgarrison
10-01-2015 05:22 PM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd gen 4Runner drivers mirror help please
